Cutting down the AOS
Rainman
If I were to cut the filler neck off the AOS at the red line in my attached picture, what could I use to close it off? Do you think a simple vacuum cap (those rubber stretchy types) and a hose clamp would suffice?
I need some space back there for an A/W intercooler that is quite large. I would be filling the oil through one of the cam tower plugs.
Official Rennlist
Borat Impersonator
Borat Impersonator
why not just delete the AOS and replace it with this
https://www.928gt.com/ps-40363-321-p...separator.aspx
and mount it where ever you want
Campeck Rulez
All oil catch cans are kinda generic and can be used on any vehicle.
I had this one on my 944.
http://www.accmachtech.com/catchcans.asp
Official Rennlist
Borat Impersonator
Borat Impersonator
the provent is much more than just a catch can. they are used on supercharged 928s to aid in breather problems and 2/6 bearing failure when cornering.
of course it would fit a 944 just have to make sure its hooked up properly
Have you looked at the plugs that are used pool filtration systems?
