Resurrecting Frankencar
Old 02-21-2011, 11:22 AM
  #166
Lemming
Lemming's Avatar
Originally Posted by seafeye
Are you using the stock latches for the rear glass?
On my 944 track car i have yet to find a way to secure it down. Ideas???
No. I have lexan in the hatch and it is held down by two rubber latches.
Old 06-04-2011, 10:24 AM
  #167
Lemming
Lemming's Avatar
Well, Franky II is about to morph into Franky III. After nine months of trying to work out the bugs associated with forced induction, I have decided to go another route. This time I'm doubling the number of cylinders in the car. I have sold my two 968 engines to fund the build. Say hello to V8 power. The tear down and build begins today!
Old 06-04-2011, 11:47 AM
  #168
North Coast Cab
North Coast Cab's Avatar
ST2?
Old 06-04-2011, 12:37 PM
  #169
Lemming
Lemming's Avatar
Originally Posted by North Coast Cab
ST2?
Yep!
Old 06-05-2011, 07:40 PM
  #170
Lemming
Lemming's Avatar
Pulled the 968 engine today. Waiting on parts for the transplant.
Old 06-05-2011, 07:47 PM
  #171
Rudeboy42
Rudeboy42's Avatar
Originally Posted by Lemming
This is a little off topic, sorry, but what is that on the end of your exhaust? Is it some kind of silencer? If so where did you get it?
Old 06-05-2011, 08:26 PM
  #172
Lemming
Lemming's Avatar
Supertrapp exhaust, but it is no longer on the the car.
Old 06-07-2011, 03:44 PM
  #173
Lemming
Lemming's Avatar
Will be delivering the 968 engine to the new owner on Saturday. In the meantime, I've been stripping the LS1 to do a rebuild.
Old 06-19-2011, 11:49 PM
  #174
Lemming
Lemming's Avatar
Making progress. Engine was refreshed and installed today. Custom headers fit well, they go back to the fabricator tomorrow to finish up (tack welded to check fit). Only problem at this point is the the dual master brake setup is rubbing against the valve cover. Will move it over 1/2" to fix the problem.
Second pic shows the weight of an LS1 engine. Engine had the clutch, headers, cross member, and alternator installed. Total weight 437 lbs.
Old 06-19-2011, 11:53 PM
  #175
Rudeboy42
Rudeboy42's Avatar
How much did the 968 engine weigh?
Old 06-20-2011, 12:05 AM
  #176
Lemming
Lemming's Avatar
I did not weigh it prior to selling it But I asked my friend who bought it to weigh it before he installs it. Will post when I find out.
Old 06-20-2011, 04:42 PM
  #177
DVC
DVC's Avatar
Good pace Tim!
Old 07-20-2011, 11:23 AM
  #178
Lemming
Lemming's Avatar
The last month saw very slow progress while I waited for a part to come in (external oil line adapter) and travel for work. The part is finally here and things are moving along.
Clutch is in and working fine. Using the Wilwood 13/16 master was a good idea but I'm going to have to build up some calf muscles for those long races (either that or learn to shift without the clutch!).
I sprayed the headers with a diy ceramic coating the other day and they turned out rather well. I'll drop them in my wife's ceramic kiln tonight to cure.
Replaced the LS1 valley cover with the LS6 to reduce oil loss.
The only things I have left to do are to fashion oil lines and deal with the electrical hookups. Once those are done, it's off to have the exhaust Y-tube built and installed and I'll be done. Hoping to start the car within the next week or two.
Old 07-21-2011, 09:58 AM
  #179
Lemming
Lemming's Avatar
Cooling headers!
Old 07-21-2011, 02:04 PM
  #180
sydneyman
sydneyman's Avatar
nice! you've certainly run the gauntlet of propulsion methods!
Quick Reply: Resurrecting Frankencar
