Refinished cookie cutter wheels $400.00
I have a sad tale to tell. Last fall I found a set of rough cookie cutter wheels. I spent the winter refinishing them. When I put them on my car a couple of weeks ago the early offset made the tires rub. I think I could get them to fit, but it is not worth deengineering my 944 for a set of wheels. My loss is your gain.
4 15x7 wheels $400.00 plus shipping from Denver, CO. If you are remotely local, I can meet you with them.
When I first bought them.
![](http://i299.photobucket.com/albums/mm301/Stogie25/Porsche%20944/STA71351.jpg)
After stripping, poliishing, priming and painting.
![](http://i299.photobucket.com/albums/mm301/Stogie25/Porsche%20944/STA71359.jpg)
Hand painted center caps. These were redone to fix the chipping seen in the picture.
![](http://i299.photobucket.com/albums/mm301/Stogie25/Porsche%20944/wheelcaps.jpg)
After more polishing and clear coating.
![](http://i299.photobucket.com/albums/mm301/Stogie25/Porsche%20944/STA71362.jpg)
A shot of all four.
![](http://i299.photobucket.com/albums/mm301/Stogie25/Porsche%20944/STA71360.jpg)
On the car. They look great. If only they didn't rub.
A shot of all four.
![](http://i299.photobucket.com/albums/mm301/Stogie25/Porsche%20944/STA71403.jpg)
Hey Man
Count me as one of the odd ***** that like the look of CC's on an early car. Your price point might be a bit high but you did a great job on them. I worked over the CC's on my old 83 also.
![](http://forums.rennlist.com/upload/picdisc3_020_copy9.jpg)
There are 2 things you can do to keep those wheels on your 1988. Either get an alignment and change your camber to around -2.5 degrees in the front and -1.5 degrees in the rears and those wheels and tires should fit without any rubbing issues. It would be better if you can run a narrower tire like a 195 or 205/55/15. I have a set of Cookies on my 1988 944 Spec Race car when I do open track events with 15x7 et23.3 with 225/50/15 Toyo RA1 tires and there is no rubbing at all. Then again, I do have -3.25 degrees of camber in the front and -2.5 degrees in the rear. You can also roll the fender lips a little for additional clearance.
