FS: Black/white gauges $75
Rainman
Set of white letters/black face instrument cluster from a '79 924. All gauges look in good shape and come with wiring pigtails. You may need to do a bit of simple wiring work to get the 924 tach to work on the 944 as described in these threads:
https://rennlist.com/forums/924-931-...-in-944-a.html
https://rennlist.com/forums/924-931-...e-upgrade.html
$75 plus shipping
$75 plus shipping
Rainman
remove your sunroof panel, remove the two screws from the roof slider receivers, remove the receivers, put the manual latches in their place, screw them in.
on the car side remove the outer cover of the slider arms and the arms themselves and you can use that, or you can remove the entire little boxes and put the manual latch receivers i am including in its place
thats it
thats it
