N/A Max HP?
I have a webcam installed in my car, I'd like to say that made a difference. If feels like it did at least. The car pulls till redline instead of the power falling off.
1 Post
It does not increase throttle response. I had one of these things on my car and it was junk. It makes it difficult to drive smoothly, and not any faster feeling. But that's my opinion
Well, I noticed it anyways.
Maybe thats a byproduct of driving an NA - you notice even minuscule changes in performance, because you don't have much to start with!
The cam just changes the relationship between throttle cable input and throttle opening to make it linear rather than progressive. I used a dremel and made my OEM cam into a "hybrid" cam by cutting of about half of the "finger" that slowed down the early throttle application. +30 HP right there.
imo taking out the rear seats is useless, you lose a place to sit people (however cramped it may be) and it makes the car look unfinished.. Plus have you ever held rear seats, they are pretty much just foam.
Captain Obvious
The heaviest part of the rear seats is the fold down upper section.
Russell Berry's MAXHP 944 chips are IMO the best out there. Dyno proven results.
Those throttle cams are purely for throttle response only, no power gains.
Suspension and good brakes make these cars faster than others.
Removing excess weight helps too, as stated. The sound deadening material is heavy...factory power seats are @ 50kgs, the original bumpers, spare tire...etc.
Rainman
i redid the carpet in my car and was shocked at how heavy the original insulation was...tossed it all and replaced with some generic carpet pad, car is just as quiet but probably 30lbs lighter
I'm trying to figure out how a webcam adds horsepower. I have a webcam but its mostly used at home late night in front of the computer where noone else sees me... J/K!
1 Post
The supercharger stage 2 kit with 222whp is the max it could go without killing the engine I think. But may be a good thing to upgrade some parts to handle the power in the engine ether way.
