My 944 V8 LS2 made the cover...
#61
Almost Addicted
Travis, it is probably on the other board somewhere, but what did you do to compensate for the (loss of) brake booster? How is pedal feel?
#62
It's a bit spendy but affords a no compromise conversion. Works like the setup in the 964. I've driven a lot of these swaps and I highly recommend boosted brakes.
#64
Almost Addicted
Alex- I'm using an electric booster from http://www.abspowerbrake.com/
#66
DVC,
My wife has a "vacation" coming up mid - April.
I'm thinking a trip to Daytona, and drive Al's car. He is running the same setup.
(I may have some 948 work to do while I'm there, but WTH?)
#67
Almost Addicted
#68
Tilton 72-610 Balance Bar = $159 @ CarSop, Inc.
Steel Mounting Bracket = Fab yourself for close to Nada, or ~$200 with the pushrod
Wilwood master cylinders are ~$79 each
___________
Total = $532 +/-
But, this will still be a Manual brake system. Great for the track, but could be tiring on the street.
___________
Total = $532 +/-
#69
Almost Addicted
___________
Total = $532 +/-
___________
Total = $532 +/-
#71
Almost Addicted
NA front calipers are worthless on the rear of any 944 arm because the calipers on the front have 76mm ears and the rears are 94mm.
A bolt-on upgrade would be turbo fronts on the rears with washer/shims OR soon to be released RX7 4x36 calipers with Turbo rear rotors. You'll need 87-up Turbo rear 100mm offset rotors.
#74
Almost Addicted
#75
I recommend keeping an eye on the corvette forum and LS1Tech classifieds. Also an online source that searches wrecking yards.
Sounds like a great vacation Greg!
DVC,
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
