Which bushings?
Which bushings?
I am going to upgrade my suspension on my street 944 NA (weekend car):
- Koni sport all around
- 225 lb/inch springs
- 26mm torsion bars
- 968 M030 sway bars
I want to know what you would recommend for the bushings. I would like to avoid an extra harsh ride, so I was thinking about sticking to OEM rubber (but replacing with new ones).
I am getting the 968 caster blocks, and OEM rubber or Weltmeister restoration kit for the front of control arm. HOWEVER I can't find new OEM rubber bushings for the rear bushings.
- Would the Weltmeister poly graphite set in the back be overkill / too harsh ?
- Should I not bother messing with the rear bushings if I want to keep rubber ? (although I'm going to get the torsion bars changed anyway?)
Thanks !
- 26mm torsion bars
Thanks !
Administrator - "Tyson"
Does anyone make a solid / spherical style bearing setup for the 944 control arms?
Yea I could do a search....
I bought a set of custom chromoly control arms with spherical joints through VT951 on this board. His brother is a custom fabricator and did a fantastic job.
https://rennlist.com/forums/924-931-...ntrol-arm.html
Wasn't thinking suspension when that thread popped up, still a ways away from that step of the rebuild, but something to keep in mind.
Thanks!
Same idea behind a control arm option for the 928 I'm hoping to do:
http://simardracing.com/Suspension.html
Good work! My recommendation for greasing polybronze is SKF's LGEV2 grease: http://www.mapro.skf.com/pub/pds/LGEV2_datasheet_e.pdf
