Pics - front end stripped & raised for engine install
I got stuck into the car today and prepped the front end to get the motor back in. I decided I will put it in from underneath this time. I added more pics to the web site as usual <a href="http://home.satx.rr.com/grehome/" target="_blank">My web page</a>. I attached one here though.
I did the braided fuel lines today as well - man those dremel grinders make it sooo easy to cut off the existing crimp fittings where the fuel lines go through the fender wall.
Cheers,
Wayne
Cheers,
Wayne
I AM SOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOOOO
JEALOUS!!! man you car is gonna look soooooooooooooooooooooooo good when its done!!!!
GREAT JOB!
GREAT JOB!
[quote] Don't forget to run you cruise and throttle cables before you put the motor in!!! <hr></blockquote>
Sure thing Perry, I came up with a big list of stuff to do in sequence so that the job would be as simple as possible while so much of the car is apart.
[quote] btw whats the VW? car out there? <hr></blockquote>
Thats my 90 E30 BMW 325i - which refuses to start at the moment (bad crank angle sensor I think).
Its funny but I really enjoy working on the Porsche - even though I dont have to and its usually a bitch to get access to everything, but I find it a pain to work on the BMW even though I really should have it running and its a much easier car to work on as well. Sick eh ?
Wayne
Wayne
Professor of Pending Projects
"Sure thing Perry, I came up with a big list of stuff to do in sequence so that the job would be as simple as possible while so much of the car is apart."
Can you shared that list?
This is one restoration I have been following closely. Great work!! Looking good!! WOW, I only wish I could go into the same level of restoration with mine.... keep us in the loop with all those great photos youhave been posting in your site!!
Hows this for a method of moving the engine easily whilst still maintaing a low profile. The dowel roller idea is definitely and old method but a good one! It took only about 5 minutes to get the engine in place - single handed.
Cheers,
Wayne
Cheers,
Wayne
