View Poll Results: Have you had problems with your N/A tranny?
Yes
16
32.00%
No
33
66.00%
I installed a 944 S2 tranny
1
2.00%
Voters: 50. You may not vote on this poll
have you had problems with your N/A tranny?
Old 12-15-2009, 08:24 PM
m73m95
m73m95's Avatar
Originally Posted by V2Rocket_aka944
maybe ive just been driving it for so long now i dont notice any more. its been 6 months.
How does it do with slower "city" highway driving (55-60mph)? Are the rpm's so low that it lugs the engine?
I know 5th is shorter in the turbo boxes, but its still not as low as the NA's.
I've been wanting to swap out my trans for a turbo one, but I was worried it would be to high geared for the NA engine to pull at lower highway speeds.
Old 12-15-2009, 09:47 PM
V2Rocket
Rainman
V2Rocket's Avatar
it works just fine, in 4th even at those speeds with some throttle it still picks up decently. of course if you want to pass someone you can go to 2nd and still have some windup room, 3rd goes to 105 or so.
it takes a fraction of a second longer of clutch slipping off a light but it really is nothing.
Old 12-16-2009, 03:57 AM
Litespeeds
Litespeeds's Avatar
Go out and test drive any 944 NA and you will see how much acceleration you are missing. Of course you have to test drive a 944 that is still in fairly good condition.
Old 12-16-2009, 04:12 AM
FRporscheman
FRporscheman's Avatar
I have had one fail (my '84, original gearbox). I replaced it with a used early one for $300 about 8 years ago (and it's still working). Later I bought a late one for $150 as a spare.
It seems logical to replace a failure-prone part with a higher quality part, but NA trannies are easy to find and fairly cheap, and they last a good while, so for now I'm going to stick with them.
My biggest problem with the NA tranny is how heavy it is, I threw out my back last month moving some engines and a 944 tranny... Lift with your legs, guys!
Old 12-16-2009, 07:58 AM
V2Rocket
Rainman
V2Rocket's Avatar
my NA trans blew out that day and i had it out of the car by dinnertime, the next morning got the 951 box in and took it for a drive, even then didn't really notice a difference.
the trans is maybe 150lbs, *****.
lol
Old 12-16-2009, 06:13 PM
porrsha
porrsha's Avatar
Originally Posted by tifosiman
It's not a matter of the "output shaft and internals".
The Ring and Pinion gears are what fail on an N/A trans, due to many reasons. You will find that cars that have higher mileage, have been abused, and/or have been driven for a length of time with a failing clutch center are candidates for transaxle failure.
Tolerance levels increase with wear as well. Ideally you would have the transaxle cracked open at specific intervals to have the lash adjusted for the r&p so that they fit together properly. Otherwise the increased tolerance will cause failure, especially in a high shock instance (like dropping the clutch at high rpms or speed shifting). However there is no mention of regular lash adjustment intervals in the FSM.
The S2 transaxle (and 951) have a different r&p ratio (among other differences of course) that make for a more robust r&p.
Keep in mind that if you swap to a S2 trans that it is geared differently than your 944 N/A trans, you may not like it.
Agreed...the application is primarily for DE's and autocrosses so the shock and wear value will be increased vs strictly street. The lower 5 th gear will be valuable for DE's maybe..depends on the track. The LSD issue is huge for autocross, more so than the DE's. When I had my 997 and GT-3 I rarely if ever had the PSM kick in (smooth driving) it was a giant pain in the butt for autocrossing becuase you can never turn it off.
Based on this feedback and the other I have received I am looking for an S2 at this point.
Old 12-17-2009, 12:18 AM
kennycoulter
kennycoulter's Avatar
i actually blew out my original trans, clutch already replaced, BUT......i didn't blow out the ring and pinion, i seemingly chipped the gears in second (shifting fast). it would always pop out, but if you drove easy, you could hold it in second. i gave it to andy (nine44) for helping me out on my car, hoping he could reuse it.
the "new" one i bought was from an 84 with similar miles (about 120,000) but has always seemed like it has more slack and whine.
i drive my car easy now. it isn't worth it to mess up a daily driver and force it off of the road because some girls want to race you...
Old 12-17-2009, 03:57 PM
lovemyp-car
lovemyp-car's Avatar
my stock n/a trans has 216,700 miles on it, the last 3 with a 400 horsepower v8 pounding on it, and it's still drivable, but it's starting to lose it a little, it's pretty rough and second gear is almost impossible to get into at speed...gonna need a turbo trans soon
Old 12-17-2009, 04:03 PM
Dougs951
Dougs951's Avatar
Ethan-How is the paint coming?
Old 12-17-2009, 04:14 PM
pormgb
pormgb's Avatar
I recently replaced my whiny transmission after 9 years, for two and a half of the nine it survived my turbo charged motor. The N/A tranny was sweet with the turbo but I could not launch the car due to the fear of my R/P breaking, I love the 6 speed.
Old 12-17-2009, 06:28 PM
lovemyp-car
it's coming along, i need to finish figuring out what i'm going to with the hood so i can paint that, and the whole car needs a wetsand/buff, then it will be shiny instead of bumply
sorry for the hijack!
Quick Reply: have you had problems with your N/A tranny?
