"Powerchip" ecu chip upgrade for 944, S2, 951, 951S, 968
Found an ad for this in excellence
<a href="http://www.powerchipgroup.com/porsche" target="_blank">www.powerchipgroup.com/porsche</a>
complete with .pdf info sheet and dyno charts etc.
What do you guys think?
I'll believe it when I see a back-to-back dyno comparison not from the manufacturer.
Hey they do have 14 day money back garuntee so maybe I will get one and so some dyno runs myself!
<img src="http://www.powerchipgroup.com/images/home_windingroad.jpg" alt=" - " />
This picture is on their main webpage. I guess they do not know how to use a real sportscar....
Eirik Kvello-Aune
<a href="http://www.diateam.no/porsche" target="_blank">www.diateam.no/porsche</a>
Eirik Kvello-Aune
We have two top-rated Porsche-trained mechanics here in Ottawa. Both recommend against changing the chip, noting that (surprise!) Porsches are much more tightly designed than most cars, and dumping undesigned power on all the other parts of a Porsche with a hot chip gives more problems than it's worth.
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">In standard form, the Porsche 944 Turbo Stage 1 produces 217 hp, however the addition of a Powerchip Gold 93 will increase the power to 253 hp. In addition to the extra power, the torque is also increased. The 944 Turbo Stage 1 produces 243 lb.-ft standard, and this is increased to 281 lb.-ft. This means more pulling power especially up hills.
Your car uses 2 plug-in pull-out chips. Fitting is easy and the Powerchip can be installed in about 30 minutes. The Powerchip is currently in stock at our Upgrade Center located in Santa Monica, California, and will be delivered by FedEx Next Day courier. You simply read and follow the full fitting instructions (including diagrams and photos) to install the new Powerchip. This can be done using simple tools, and it is designed so that any home handyman can complete the task, quickly, simply and easily.
Click here to view a nine page PDF document (Adobe Acrobat required) with further information about the Powerchip for your car.
Porsche - 944 Turbo Stage 1
Make Porsche
Model 944 Turbo Stage 1
Fuel Required (More info) 93 Octane
Power Standard 217 hp
Power Powerchip Gold 93 253 hp
Torque Standard 243 lb.-ft
Torque Powerchip Gold 93 281 lb.-ft
Gold 93 Powerchip USD $640
</font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica"> </font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">In standard form, the Porsche 944 Turbo Stage 2 produces 217 hp, however the addition of a Powerchip Gold 93 will increase the power to 266 hp. In addition to the extra power, the torque is also increased. The 944 Turbo Stage 2 produces 243 lb.-ft standard, and this is increased to 294 lb.-ft. This means more pulling power especially up hills.
Your car uses a turbocharger to maximize power of its engine, however your car does not use sufficent boost to produce good power. There are 2 modifications which we perform on your car. Firstly we change 2 chips in your cars ECU which changes fuelling, timing and boost output. Secondly, we increase the boost output of the turbo charger even further by modifying the wastegate. The Powerchip is currently in stock at our Upgrade Center located in Santa Monica, California, and will be delivered by FedEx Next Day courier. You simply read and follow the full fitting instructions (including diagrams and photos) to install the new Powerchip. This can be done using simple tools, and it is designed so that any home handyman can complete the task, quickly, simply and easily.
Porsche - 944 Turbo Stage 2
Make Porsche
Model 944 Turbo Stage 2
Power Powerchip Gold 93 266 hp
Torque Powerchip Gold 93 294 lb.-ft
Make Porsche
Make Porsche
944 Turbo
.pdf data file with dyno charts and other statistics
<a href="http://www.powerchipgroup.com/datasheets/2/Por0006.pdf" target="_blank">http://www.powerchipgroup.com/datasheets/2/Por0006.pdf</a>
or if you are an S2 guy (girl)
.pdf data file
<a href="http://www.powerchipgroup.com/datasheets/2/Por0004.pdf" target="_blank">http://www.powerchipgroup.com/datasheets/2/Por0004.pdf</a>
Products
In standard form, the Porsche 944 S2 3.0 16V produces 208 hp, however the addition of a Powerchip Gold 93 will increase the power to 228 hp. In addition to the extra power, the torque is also increased. The 944 S2 3.0 16V produces 207 lb.-ft standard, and this is increased to 225 lb.-ft. This means more pulling power especially up hills.
Your car uses a plug-in plug-out chip. Fitting is easy and the Powerchip can be installed in about 30 minutes. The Powerchip is currently in stock at our Upgrade Center located in Santa Monica, California, and will be delivered by FedEx Next Day courier. You simply read and follow the full fitting instructions (including diagrams and photos) to install the new Powerchip. This can be done using simple tools, and it is designed so that any home handyman can complete the task, quickly, simply and easily.
Porsche - 944 S2 3.0 16V
Make Porsche
Model 944 S2 3.0 16V
Power Standard 208 hp
Power Powerchip Gold 93 228 hp
Torque Standard 207 lb.-ft
Torque Powerchip Gold 93 225 lb.-ft
Gold 93 Powerchip USD $490
.pdf data file
Products
Make Porsche
or 1986 Porsche 944
.pdf data file
<a href="http://www.powerchipgroup.com/datasheets/2/Por0001.pdf" target="_blank">http://www.powerchipgroup.com/datasheets/2/Por0001.pdf</a>
In standard form, the Porsche 944 2.5 Unleaded produces 148 hp, however the addition of a Powerchip Gold 93 will increase the power to 167 hp. In addition to the extra power, the torque is also increased. The 944 2.5 Unleaded produces 141 lb.-ft standard, and this is increased to 157 lb.-ft. This means more pulling power especially up hills.
Porsche - 944 2.5 Unleaded
Make Porsche
Model 944 2.5 Unleaded
Power Standard 148 hp
Power Powerchip Gold 93 167 hp
Torque Standard 141 lb.-ft
Torque Powerchip Gold 93 157 lb.-ft
Gold 93 Powerchip USD $440
.pdf data file
Make Porsche
or 944 Turbo S
.PDF data file
<a href="http://www.powerchipgroup.com/datasheets/2/Por0007.pdf" target="_blank">http://www.powerchipgroup.com/datasheets/2/Por0007.pdf</a>
Products
In standard form, the Porsche 944 Turbo produces 247 hp, however the addition of a Powerchip Gold 93 will increase the power to 296 hp. In addition to the extra power, the torque is also increased. The 944 Turbo produces 258 lb.-ft standard, and this is increased to 307 lb.-ft. This means more pulling power especially up hills.
Porsche - 944 Turbo
Make Porsche
Model 944 Turbo
Power Standard 247 hp
Power Powerchip Gold 93 296 hp
Torque Standard 258 lb.-ft
Torque Powerchip Gold 93 307 lb.-ft
.PDF data file
Products
Porsche - 944 Turbo
Make Porsche
Model 944 Turbo
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Power Standard 148 hp
Power Powerchip Gold 93 167 hp</font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">When monkeys fly out of my ***!
With my 2.7 I'm only producing 168HP... that's with APE chip, MSD ignition, Bursch header, 2.5" custom open exhaust, AC delete, and rosary beads for a timing belt
S
S
Done With Sidepatch
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by Skip:
<strong>When monkeys fly out of my ***!
</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">Well, that about says it all...Topic closed!
As I consider the above statement further I can only imagine how painful the above proposition would be...
Very funny Skip <img border="0" alt="[cheers]" title="" src="graemlins/beerchug.gif" /> Thanks for the laugh.
<strong> </font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Power Standard 148 hp
S</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">The european 1983 944 2.5L 8v produced 163 DIN HP. Why shouldn't the US version also be able to do that with the propper engine management? (Screw emmission requirements).
Eirik Kvello-Aune
Eirik Kvello-Aune
