Best timing/balance belt - Porsche brand worth it?
I'm about to change the timing and balance belts on my S2. I noticed that the Porsche brand ones are hideously expensive, at around $130. There also seem to be Gates branded ones at around $45 and others at even lower prices.
Is it worth going for Porsche branded? It seems that the original belts seemed to last a long time, whereas perhaps other brands have failed after 4-5 years.
Any experience with particular brands failing?
Location: Brisbane, Australia (Formerly: Sunnyvale, CA)
I was under the impression that Gates is the OEM for the Porsche belts. The wider S2 belts are generally a bit dearer than the standard 944 belts -- I got my Gates timing belt from Pelicanparts.com along with all the rollers and seals (I found shipping to Oz was economical.) Price at Pelican for a Gates S2 belt is currently $24.25.
Team Owner
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
gates is obsessed with the manufacturing of belts... and yet techs say, "oem belts please."
gates is developing new timing belts now that are arguably some of the best - so go figure...
Team Owner
where do i source Gates belts ? reason i am asking is Porshce sells everything individually and that's a great oportunity to go oem on everything else including the H20 pump, cam chain, seals etc... and do GATES on just the belts, which i am perfectly comfortable doing.
I used non oem belts once and had the balance shaft belt snap after 6k miles...other than that, I've always just bought the oem belts and have never had a problem...ymmv...
Rainman
i just pulled my previous belts off my car after 25,000 miles or so and 3.5 years and they looked nearly new still. not even a hairline crack or anything. one was gates and one was conti.
It ain't rocket science. TB's have been mainstream for more than 20 years, materials and manufacturing methods have improved along the way. I have Gates on both my cars (one is the Rennbay kevlar TB) and no worries. Gates may be a common brand, that doesn't mean it's crap, quite the opposite. Unless the box says Yua Lien Wau Timing Belt and Shoelace Manufacturing, you're OK.
