Compression Ratios for 8v na's
Why? The made the the car the same for USA and Euro regs. One car for all markets. Also fuel and emissions regs were changing in Europe driving this change. Also all 944's (and most Porsches) from the 86 Turbo were rated the same hp in USA and Europe.
In 1987 they also announced the removal of 4-star (98 RON) gas from most European gas stations with effect Jan 2000. I guess this might have contributed to Porsche lowering the compressions on the later 944's.
M758: From what you said the Euro rating of 163 was without a Cat for the early cars but on the 1988s the Euro and US cars had the same HP. Did the Euro Cars have Cats in 1988? If so how much HP would I stand to gain with a test pipe (or bypass)? or would the amount be not enough to be worth getting the bypass pipe?
Here's an old post I found in search about the S2/2.5L rod dimensions:
I don't believe it worth it for a street car.
Rainman
I think you are wrong Spencer. The S2 rods are dimensionally the same as the 2.5L, it's just that they attach to the pistons at different locations to make up for the different stroke. So if you want to build a 2.8L stroker from your 2.5L, you just need the S2 crank and custom pistons. I think Andial makes the correct size piston for the turbo 2.8L, you would just have to have them make a set up with a higher compression.
Looks like they could have made those Euro pistons a flat top and kept the same compression by using deeper cut-outs for the valves, maybe even clearing the interference issues.
There have been attempts to make non-interference pistons for our cars but most found out that due to crown thickness with deeper cutouts, it wasn't a very good idea. Don't know if Porsche thought of the same thing or not.
