A few quick answers please --- LR Vacuum hose install
I just finished installing the LR vacuum hose kit on my car. I ended up with about 10 ft of extra hose, and 1 extra metal "T".... I used 3.
Does this sound right, or did I miss a line with a "T" in it somewhere? I searched and couldn't find where someone said they had an extra "T", but I've replaced all the vacuum lines I can see under the hood. Even the hoses from the firewall to the heater control valve and the vacuum canister...
Thanks for the input,
Throttle body to thermal valve to brake booster?
Also remember the kit is the same for N/A and 951 the same, but the 951 has more points for it to connect to! (recirc valve)
That sounds right. I remember that I had a bunch of extra hose. I don't remember if I had an extra T, but it seems like I used one in an extra place compared to the factory places.
Yeah yeah, I did the TB to thermal valve to the evap can.
Then other TB to "T" to FPR and damper (use "T") and other side of "T" to other side of the evap can valve (with adjustment screw on it)
Then brake booster (Because the brake booster gets its vacuum from the large hose from the intake) hose (also add in the 1-way valve) to the firewall and "T" to the vacuum canister.
Then a short hose from the firewall to the heater control.
Leaves me with 10ft of hose, and 1 extra "T".......
Oh, everything matches up with what I took out..... just wondering if I forgot a line somewhere.
If its for a 951, I'll quit worrying about it. I can always use up extra vacuum hose.
From after I did the vacuum lines but before I installed the MBC..
![](http://i179.photobucket.com/albums/w305/avimgod/100_1721.jpg)
line from left to right is the recirc valve line... and as I remember I had about 4 feet extra, but I also installed a Laust special vacuum manifold (brass bit on the intake) so I only used 1 T for my mechanical boost gauge...
I have pieces in transit from Australia to allow me to delete the mechanical boost gauge and replace it with LEDs driven by the MAP sensor... much more accurate, much more resolution... much more flexible...
