The Magic 200 HP for NA?
Old 02-07-2013, 02:52 AM
  #151
16valver
16valver's Avatar
Diameter wise? probably. they just have higher static compression as well as valve reliefs for the extra valves (as mentioned before).
I feel like you guys are probably right but something deep down inside tells me it would be worth it to look at a side by side comparison of the two blocks. I wonder if their part numbers are the same?
Old 02-07-2013, 11:53 AM
  #152
V2Rocket
Rainman
V2Rocket's Avatar
the blocks are absolutely identical. same crankshafts too. rods? and pistons are S-specific.
one thing to be aware of depending on model year - 86 and 87 might have a different sleeve to the oil cooler housing.
Old 02-07-2013, 03:58 PM
  #153
944meister
944meister's Avatar
I'm thinking of the 2.7l block... Disregard my post
Old 02-07-2013, 05:05 PM
  #154
333pg333
333pg333's Avatar
Based on those pictures a few pages ago the two heads certainly didn't seem identical to me as far as water passages are concerned.
Old 02-07-2013, 07:17 PM
  #155
V2Rocket
Rainman
V2Rocket's Avatar
my mistake
Old 02-07-2013, 08:52 PM
  #156
Arominus
Arominus's Avatar
The 2.5L block is the 2.5 block. Same with the crank, you just have to change the pistons and possibly the rods to run the 16v S head. The S2/968 heads require the 2.7/3.0 block.
Old 02-07-2013, 09:12 PM
  #157
Fara
Fara's Avatar
True. Unless you get Lindsey Racing or someone similar to change the coolant and oil passages to match.
Old 02-07-2013, 11:51 PM
  #158
piperporsche180944
piperporsche180944's Avatar
Originally Posted by LP944
I drove my friends 1979 928 and that thing is scary fast
Cool story bro
Old 02-08-2013, 02:43 AM
  #159
Arominus
Arominus's Avatar
Haha true that, i suppose you can fix any problem with the proper application of cubic dollars.
Old 02-08-2013, 04:48 AM
  #160
333pg333
333pg333's Avatar
Not what I was saying. The two heads appear to have coolant passages in different shapes which would involve some overlap and possibly create an issue with the headgasket.
Old 02-08-2013, 10:08 AM
  #161
ZR8ED
ZR8ED's Avatar
If you don't have cubic dollars, you can also get there with cubic skill. Machine skills, port/polish skills etc. There are lots of ways to impvove the VE of the engine, that alone may not make power, but they can "free up" wasted hp used to turn reciprocating mass, and pumping oil and water through poor flowing passages.
If all else fails. Cubic *****. Pretend you have the skill, and try the machining yourself anyway.
Old 04-20-2015, 12:25 PM
  #162
mattipuh
mattipuh's Avatar
got 195.8hp.
dialed down to 193.8 for safety reasons.
final setup for 944 2.5 8V, 194hp fw hp.
some magic voodoo stuff.. ,)
Old 04-20-2015, 01:49 PM
  #163
V2Rocket
Rainman
V2Rocket's Avatar
in english thats about 180-190 lbft of torque...
big displacement
what else
Old 04-20-2015, 02:32 PM
  #164
H.F.B.
H.F.B.'s Avatar
Originally Posted by mattipuh
got 195.8hp.
nice numbers, congrats; where did you get the additional hp from.
We know your engine already has some modifications as you stated on pelican parts forum:
- Wössner 11.5:1 Pistons
- 944 Turbo forged rods
- 2.5ltr engine block with steel sleeves
- Balanced FW and crankS.
- vibration balancers removed from the engine
- Jenvey ITB's + Pipercross airbox
- Tatech 32Lite engine management
Old 04-20-2015, 03:01 PM
  #165
H.F.B.
H.F.B.'s Avatar
ok, I found some information on facebook. Now it's clear.
Quick Reply: The Magic 200 HP for NA?
