VR 944 PROJECT
#256
From: Nashville///'84 944NA, Virtual Luftwaffe pilot, Fighter Ace online
Still waiting...(tap, tap, tap)
Ah, well...guess I can do some cleanup or something on the Scirocco.
A friend wants me to buy his '81 five-speed 928...the car is very clean, but has a few minor issues with suspension, and one major oil leak from the rear of the block.
#257
Finally got the valve springs in, and the valves installed in the head. Torqued the main bearing caps (twice, because I got interrupted, and wasn't 100 % sure that they all got the same torque (22lbs/ft, plus 180 degrees) so I unbolted and redid them to spec). Oddly enough, torque spec for the rod bearings was the same, except only 90 degrees extra. I forgot to have the new head bolts picked up from the supplier, so I have to wait till Monday to install the head on the block. Ah, well, I still have other things to do (I wound up buying the 928), so no biggie.
#262
#265
Have a vr6 turbo in an mk2 vw that I've had for a decade. Interested to hear if you were able to get this on the road. The pictures I've seen on the 924 attempt indicate there would be a problem with the porsche cross member and the vr6 oil pan. This cost to rectify would be significant in a dry sump system for the vr6 ... which is out there but pricey.
#266
Team Owner
From: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
four and a half years ago....
I hear that giant sucking sound (future butthurt) but, this guy sounds like he knows what he's doing. plus, he's a 928 guy and Lord knows thems things are one serious nightmare. maybe he can pull this off.
three years ago...six months later... two years ago..
I'm still not posting (I like it and keeping an open mind about a smooth running, modern substitute for that tired old lawn mower)....
today... do bears **** in the woods. yeah, safe bet another one crashed and burned.... is this as bad as the faux dash re-do fraud? no. not near as bad. this guy appears to have at least tried....
but, the effort needs to yield some performance much less a ton and a half of scrap... the stock engine that came with the car is economy. the VR engine is better plus a few extra foot-pounds etc....
would-it-a been cool? yeah I guess (and kudos for the sound with straight pipe, SLP, etc).... but still in need of a weight reduction program and turbo in full tune, but, for some perspective; a PORSCHE 968 pullout with a Carl Faucett raptor/charger can be had in a weekend and done the job. but, without forced induction, what's to get all in a heap over?
still waiting for anything over 3.1 liters that's not a wonderfully tuned, throaty, American V8.... which also happens to be the only f_cking powerplant that works for this German car besides a mid-boosted. 3.0 S2 or '68 Turbo.
am I an *******? yeah... but I've read dozens of threads on as many car forums where endless bigoted Euro worshiper/Yankee haters think the LS motors can and only could be as worthless as the old TPI engines from the mid-80s IROCs....
and again, the next totally super awesome 944, is either crushed or rusting away in some junkyard.
NEXT.....
After doing some (ok, a lot) research, I think I've finally discovered how this can be done (VR6 swap)...and so, it proceeds... initially was thinking LS-1 swap... but the more I thought about it, the more I felt it would alter the fundamental character of the car. I don't want a Porsche that sounds like a taxicab....
NEXT.....
#267
three years ago...
six months later...
two years ago..
today...
NEXT.....
three years ago...
six months later...
two years ago..
today...
NEXT.....
#268
#270
He could write 10 944 hate books, 5 "how to make 968 look more like fake 911" and 7 "economics of taxi engine" books and still have 3 years left to complete "how I became poor from owning poormans porsche" trilogy.
It would be enough material for 2 books from hist posts alone.
