hood scoop (read inside before flaming!!)
Old 04-21-2009, 09:56 AM
  #136
harrisonrick
Captain Obvious
harrisonrick's Avatar
any more pics for us?
Old 04-21-2009, 03:16 PM
  #137
dream951
dream951's Avatar
+1. Good luck with the first start!!!
Old 04-21-2009, 04:06 PM
  #138
lovemyp-car
lovemyp-car's Avatar
sure i got some...they're not real new, but they haven't been posted yet!
thanks!!!
p.s. anyone got any tips or can come out and help with bleeding brakes/clutch? i've never done it before and i'm never sure if i'm doing it right...
Old 04-21-2009, 09:12 PM
  #139
dream951
dream951's Avatar
If your worried about bleeding your brakes/clutch you can always get a power bleeder. Very easy to use and gets everything bled quickly just by yourself.
Old 04-21-2009, 10:39 PM
  #140
VOoDOoGTX
VOoDOoGTX's Avatar
please use wire loom and dont just rap everything in electrical tape. there are factory wiring harness covers and wire loom looks ok and is cheep. There is also an electrical heat rap your can use but its expensive. i get it free from a friend that works on elevators.
Old 04-21-2009, 11:25 PM
  #141
lovemyp-car
I have loom also, the harness was originally wrapped in tape and then loomed (kinda weird i know). I was just using the tape to get stuff together so it was easier to deal with.
I'm probably going to look into getting some different colored wire loom later on. You can all kinds of colors on ebay, might be interesting!
Where do you get a power bleeder? i think i've seen them online, but i've never understood how they work, so i haven't bought any.
Old 04-21-2009, 11:40 PM
  #142
JohnKoaWood
JohnKoaWood's Avatar
I got mine from pelican or Paragon, can't remember...
You put in brake fluid, hook to cap opening on reservoir, pump up, and open bleed valves on calipers/slave cylinder...make it a breeze
Old 05-13-2009, 07:19 PM
  #143
dv8nxs944
dv8nxs944's Avatar
Any updates?
Old 05-13-2009, 08:26 PM
  #144
lovemyp-car
sure! I'd kinda forgotten about this thread!
let's see...i presented the car last night for my Senior Project Presentation...was a huge hit.
last week i discovered the source of a small smoking/steaming that i couldn't figure out. The water pump drive shaft seal was hard, and was leaking oil down onto the block, which would then smoke. Fixed that...was a big pain in the *** because i had to drain the cooling system again, remove the water pump and unplug a bunch of stuff and then put it all back together.
I still need to replace a couple of things and get a couple of things going right. I don't have o2's hooked up yet, so the idle is still very choppy...it also has no top end power and seems to get "stuck" at (best guess) around 3000 rpm and not rev up.
This last part made me realize i neglected to replace the knock sensor with that of an LT4, which is probably why it's sluggish.
Bought a flowmaster 50 series muffler with delta flow technology (should sound impressive) and i've been collecting various other exhaust tubing etc...i'm planning on doing dual 2's into a single 3 all the way back to the stock position where i'll mount the flowmaster.
Old 05-14-2009, 01:30 AM
  #145
Legoland951
Legoland951's Avatar
Hey whats the easiest way to bypass the VATS on the computer? I know they reprogram the computer so you don't need that chipped key but don't know who can actually do that.
Old 05-14-2009, 09:49 AM
  #146
CurtP
CurtP's Avatar
You're in limp home mode.
If you know the value of the resistor in the key, you can hard wire a resistor in the harness , but reprogramming is the best method.
Old 05-14-2009, 10:37 AM
  #147
harrisonrick
Captain Obvious
Pics....
Old 05-14-2009, 12:09 PM
  #148
lovemyp-car
you and your popcorn...i'll put up some more pictures soon (if i have any more!)
for my computer reprogram i used www.lt1swap.com. Brendan is very good at it...call him/email him and tell him what you need done, he'll recommend some things most likely...and it's a flat fee of 75 bucks for the reprogramming...free programs after that on the same computer (for if you add new upgrades etc.)
Ethan
Old 07-12-2009, 03:30 PM
  #149
rattlesnakeracing
rattlesnakeracing's Avatar
Talking Hood Scoop
Hey! Update time. What did you decide about the hood? Pics Pics Pics !!!
Old 07-12-2009, 06:15 PM
  #150
lovemyp-car
ok...update
check out my other thread for a couple of pictures...i've also attached some more.
so...i ended up selling the 1.6 rockers i had because they were flexing and popping off of the valves and causing trouble/lots of noise. I'm running the stock stamped steel 1.5 rockers, so the tune isn't quite right (the pcm is tuned specifically for the cam and rocker setup). I'm planning on picking up a set of comp cams chrome-moly steel 1.6 rockers soon(ish)...they should fix any flexing problems i was having and increase horsepower pretty substantially.
I've started taking the paint off of the car, down to factory primer. I'm going to put it in flat black/satin black and seal it for now, because i don't have enough money for a proper paint job (when i say i don't have enough money, i mean i have just enough cash in the bank account to keep it open...) but i should have some money rolling in soon from all the work i've been doing/selling things on ebay...so i can pick up some primer and sealer with that cash.
i have an aftermarket tach, oil pressure gauge, and coolant temp gauge hooked up, the tach is mounted on the a pillar, and i ran the two other gauges into the center console just below the cd player...i'll be making a plate out of aluminum/steel to mount them in soon, and i'll paint it black so it looks like it was supposed to be there...lol.
everyone keeps saying i need to do something about the hood, but i honestly can't and i won't...it's functional, and actually looks kick *** in person, ask doug, he saw it. Pictures truly don't do it justice, and there's really no room to go anywhere else with the intake routing at the moment, so it's staying for a while. Doug actually had a good idea to help with the look of the hood scoop...he said i should look for flaps, like they used to put in the old muscle cars, or on dragsters that i could open and close on the front of the scoop...i'll have to take a look into that!
Ethan
Quick Reply: hood scoop (read inside before flaming!!)
