Yet ANOTHER V8 944 [LS1 Powered] Pics and a sample Vid.
#31
LOL or two hey?!
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
#32
And nag away, you will be happy that you did! I started nagging in the 2 1/2 month period after that I got all my parts in under 2 weeks! I should of nagged right for the beginning.
And if you are going to track the car a oil cooler is a necessity, so you are going to be perfect.
#33
Won't be tracking it. The goal is to make a really nice daily driver, sort of a "new old Porsche" that will combine the style and uniqueness of the old cars with the power and reliability of new components. It'll probably end up costing me a lot, but the hope it that it will be worth it.
#34
The LS6 is a modified LS1.
I think most people chose the LS1 because it's cheap and easy to get used ones in good condition, and any more than 350hp is probably redundant.
I'm going with the LS3 because I wanted "crate new", and the it's only 1k more for the later generation engine.
I see no reason why the LS6 wouldn't be a sound choice, though.
cool. who knows maybe as i start adding up the cost of the swap money will dictate a LS-1 but for now I REALLY like the sounds of 405 hp on a stock engine in a 944
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
#35
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
Mark
#36
Quote from the LS1tech site...
Certainly not wanting to rain on everyones parade shouldn't you really look at the characteristics of the engine in determining which is "better"?
The LS2 is in a way more an LS6 than anything at all. Given the fact that it shares identical LS6 heads and a 2001 Z06 cam. The revlimit is likewise 6,600 and the compression has been raised to 10.9:1. The LS2 incorporates a 90mm throttle body and has an entirely new (not so great) PCM.
I certainly enjoy driving LS6 cars and also LS2 cars. They are just a little different. Where the LS6 really comes to life up top the LS2 just continues to pull from just about anywhere in the rev range.
Sure their will be fewer LS6's on the road but does that really make an engine better?
As I stated above, the PCM is completey different in the LS2 cars and incorporates many more fail safe features that are zapping performance in less than ideal conditions. Torque Management on both automatic and 6-speed cars is also a concern. Removal of such devices has created some beasts without any bolt-on's what so ever.
Just my opinion.
Just my opinion.
#37
Monkeys Removed by Request
#38
No brake booster, but a custom plate to bolt back on the master cylinder. The engine cant fit in there with the stock brake booster installed.
(Post #24)
(Post #24)
#41
Captain Obvious
Here's a question for you engine guys...I ran into a guy that races 944s, 951s and 928s...he had an 88 944S...and turbo'd it. He ran 8 pounds of boost with a custom header, turbo, wastegate, etc...I asked him about the head gasket, since a stock one probably couldn't handle this boost. He said the head was "o-ringed" and he had no head issues. What does this mean?
He did eventually blow the a rod bearing when the boost controller's spring stuck at 12 pounds of boost on turn 5 at Mosport...but at 8 pounds he said the car was sickly fast.
Sorry to hijack here....
#42
you can almost think of a widefire gasket as a fuse, I would rather blow the head gasket then damaging the engine, then at least you can retry the tune or repair the problem.
But at certain levels of power output as serious head gasket is required.
B.Rudy (b**5*h*tang) welcome aboard.
#44
Captain Obvious
94 octane from Sunoco.
He has the set up in his shop still, and he'd sell it...![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
I was thinking, "this might be a cool project"....hence I started a performance head gasket thread for starters.
