Yet ANOTHER V8 944 [LS1 Powered] Pics and a sample Vid.
Hey all,
Yet another V8 swap!
I began this swap in December of '08 and its 98% complete. Right now the cars in the muffler shop getting a custom Y-pipe made to make it connect to my old LR 3" turbo back when I had the original turbo engine. The car drives like a dream and its very quick. I did all the work myself except for the exhaust. It was a VERY easy swap thanks to the conversion kit I ordered. Well here are some pics and an older video of her drivng. Sorry for the crappy cell phone pics ill have better ones once the weather gets nicer over here.
And a quick video
And a quick video
Freedom Enthusiast
I heading to Vegas next week so while I'm there I'm going to see if I can pay a visit to Renegade Hybrids. I'm curious to see what they do and how they do it over there.
As far as the actual swap its pretty straight forward but the real things to watch out for is the cross member and oil pan clearance. You MUST grind some metal off where the steering rack bolts to the cross member so that the oil pan doesnt hit under hard acceleration when the engine torques.
Also you have to run remote oil lines and relocate the oil filter and you run the oil lines between the block and the steering rack, well they will rub on a lip on the block so make sure you wrap the lines in that area with rubber or something to cushion the oil lines.
Also if your swapping into an N/A get a turbo trans. The N/A will not hold up to the abuse of the V8. Oh and bleed the cluch BEFORE you install the engine.
Thats pretty much it, I didnt run into any major problems. Its a lot easier then people think to do the swap.
