Does Anyone have pictures of Weltmeister 200lb springs Installed
Just installed my koni yellows and the ride is still a bit cushy with the dampers cranked near stiff... I dont want the car to be too low as i daily drive it so I am open to suggestions.
Thanks in advance.
Casey
Thanks in advance.
Casey
Rainman
I have those on my car as well, very easy to swap out...
Car lowered around an inch, I had to get smaller front tires though because the 225/60/15s I had before were rubbing on hard corners, now I have 225/50s![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Car looks great lowered, ride isn't harsh at all, and it corners noticeably flatter. Not to mention there is practically zero nose dive on braking.
I can get a picture tomorrow.
Cushy? I have my new yellows set at 50% and I would not describe as cushy... Maybe you have other suspension issues above and beyond your shocks and struts...
I have these springs as well but with a metal spacer on top to maintain stock(ish) ride height. I bought them already assembled (strut/spring/mount) from a Rennlister so not sure where the spacers were sourced from but this might be the best solution for you as well.
Cparkin,
I see in your sig you are running MO30 "bars"...are you referring to the torsion or sways?
The reason I ask is, if you are running the 30mm T-bars the recommended front spring is 300lb.
