'84 944 N/A Very Wet!
Old 02-11-2009, 12:20 PM
CaCrusin
3rd Gear
CaCrusin's Avatar
Default '84 944 N/A Very Wet!
I bought an '84 944 for my 17-year-old son. Clean and in great mechanical and exterior condition. The interior is rough but repairable. (Just got a great deal on full leather 911 seats - $300/pair)
The problem is that during the current rain storms here in CA, the car is leaking. The back seats are soaked and water drips into the passenger footwell. I'm guessing the hatch seal for te back seat but not sure on the footwell.
Thanks in advance for your advice.
CaCrusiin
San Luis Obispo, CA
Old 02-11-2009, 12:25 PM
MooreBoost
MooreBoost's Avatar
look around bottom corner of windshield.
Old 02-11-2009, 12:36 PM
RedRose
RedRose's Avatar
Aside from the new seats, and carpet, don't spend more than 250 or 300 on the interior, minus whatever you should've paid for 944 seats. And have someone help him with carpet. I just did mine (I'm 18) thinking I could handle it, and it's not great. Not bad, just not excellent, and definitely not finished off yet.
Old 02-11-2009, 01:16 PM
V2Rocket
Rainman
V2Rocket's Avatar
CaCrusiin
San Luis Obispo, CA
the water on the back seats is probably coming in between the hatch glass and the metal frame; this happens on my car but i used some silicone to seal it or black electrical tape lol
as for the passenger footwell, check to see if the battery box is rusted through in any spots; common problem on these cars.
Old 02-11-2009, 01:40 PM
nkgosselin
nkgosselin's Avatar
It might just be clogged drain pipes in the cowl area. They are often gunked up.
Old 02-11-2009, 04:16 PM
CaCrusin
3rd Gear
CaCrusin's Avatar
Thanks! How do I find all of the various drain tubes? Is there a reference somewhere? I used to sell these back in the early '80s but never pulled one apart.
CaCrusin
Old 02-11-2009, 04:36 PM
V2Rocket
Rainman
V2Rocket's Avatar
remove the sunroof, they are in each corner. just get a maybe 3' piece of wire, bend a small hook on the end and push it down the tubes to see if theres anything in them..
Old 02-11-2009, 06:11 PM
El Commandante
El Commandante's Avatar
Weed whacker string works the best for clearing out drain tubes.
Old 02-11-2009, 06:43 PM
38927's Avatar
quick question, do these 911 seats bolt right in? and is it possible to use the motor to adjust the position of the seats? I think to use the electric motors cause my car already has them. however, the leather on the seats are blown.
-james
Old 02-11-2009, 07:37 PM
Tom R.
Tom R.'s Avatar
after doing everything posted above for the water and checking the battery tray for rust i found the leak in my 89. the corner of the passenger rear window. the guy at the glass shop repaired it for free! he pulled the rubber out a little, stuck a nozzle from the silicone (not silicone the other stuff) in and filled it, applied some pressure. then he took a razor and removed the excess on the window.
Old 02-11-2009, 07:59 PM
V2Rocket
Rainman
V2Rocket's Avatar
911 seats should bolt in...if you can find 12v then the power seats should work...
Old 02-11-2009, 08:18 PM
lovemyp-car
lovemyp-car's Avatar
i used to have this problem, i would get soaked carpet and back seats etc after a rainstorm...i then replaced my hatch with a fiberglass and aluminum custom one i picked up on craigslist...it was dirt cheap (75 bucks) with brand new seals...sucker seals like a volkswagen bug and i haven't had a single drop of water come in the car (except when i left the sunroof open and it snowed for two days....woops!) so try the hatch first, then work to the battery box area, and check to make sure the seal along the top of the windshield is pushed in all the way
EDIT: by the way i would get both passenger and drivers side soaked carpet, but the passenger was much worse...check the carpet under the back seats (behind the fronts i mean) to see if that is absolutely soaked, i used to get standing water back there until i fixed the hatch leak.
Old 02-11-2009, 08:52 PM
Keithr726
Keithr726's Avatar
Remove battery and inspect the battery tray, mine had a huge hole that leak into the passenger footwell.
Old 02-11-2009, 09:19 PM
J Berk
J Berk's Avatar
In that car, the passenger footwell leak is likely just cloged scuppers in the battery tray as I think somebody mentioned.
Now ETHAN...where are some pics of your car with that hatch???
Old 02-11-2009, 10:52 PM
lovemyp-car
ah...i'll do it one of these days when i actually get to work on it...
Quick Reply: '84 944 N/A Very Wet!
