hall sensor
Old 01-31-2009, 01:39 PM
RED87944S
RED87944S's Avatar
Default hall sensor
im about to get my new DME for my 944s,but before i install it,i need to figure out which way the hall sensor plugs in because the plastic around mine broke apart..do the numbers 1 2 3 line up with the metal clip going across or do the number go on the side where the clip dose not go across fully? might be a bit confusing but i dont know how explain it..
Old 01-31-2009, 01:59 PM
whalebird
whalebird's Avatar
I presume you are talking about the DME plug. Its the hall sensor referance I am not following. I don't know of any hall effects devices on our cars at all. The DME plug in is pretty straight forward. There is only one way. I am sorry I cannot be more help. But I think you could be talking about several different things here. The cam sensor on the 944s, speed and referance sensor are like hall sensors, But they all can only go one way. You can mix up the speed/referance sensor plugs, but the 16valve cars don't have a referance sender, but the cam sensor. I think a lot of us here are pulling for you to get this car running. Keep us posted and don't give up. You are gonna see this car run real soon!
Old 01-31-2009, 02:24 PM
RED87944S
RED87944S's Avatar
this should explain it
Old 01-31-2009, 02:38 PM
CPR
CPR's Avatar
The wires coming out of the top of that connector do not look good....
Old 01-31-2009, 02:41 PM
harrisonrick
Captain Obvious
harrisonrick's Avatar
The hall sensor is on the 944S model.
Sorry I can't help though...havn't taken mine apart.
Old 01-31-2009, 04:49 PM
RED87944S
RED87944S's Avatar
i just need someone to disconnect theirs and see what side the numbers are one
Old 01-31-2009, 06:36 PM
Clint's 944
Clint's 944's Avatar
S2's have the same hall sensor.....Hopefully one of them could chime in.
Old 02-01-2009, 01:50 PM
RED87944S
RED87944S's Avatar
come on anyone
Old 02-01-2009, 02:29 PM
catbug12
catbug12's Avatar
Are the color of the wires the same on both sizes of the connector? If so just match them up. In the picture it looks like black, green and red so black to black red to red green to green.
Old 02-01-2009, 02:31 PM
RED87944S
RED87944S's Avatar
thats not hard to figure out,but they dont match..
Old 02-01-2009, 03:17 PM
jstand22
jstand22's Avatar
I think the 1,2,3 goes across the side the clip crosses, as that is usually the front of the plug
My car is covered up but I'll try and take a look in a little.
Old 02-01-2009, 07:39 PM
RED87944S
RED87944S's Avatar
thanks,it be nice if u check..i dont want to ruin another dme
Old 02-02-2009, 11:33 AM
RED87944S
RED87944S's Avatar
tryin to put it in today
Old 02-02-2009, 12:07 PM
RED87944S
RED87944S's Avatar
i just picked it up from usps,come on someone tell me
Old 02-02-2009, 12:46 PM
RED87944S
RED87944S's Avatar
i just cut the broke plastic crap,i just wanna connect the wires,seems safer..i need to know what wires to connect,they are all different
Quick Reply: hall sensor
