hall sensor
#31
Captain Obvious
that's a ground...do as per previous...remove/sand/clean and retighten snugly. also, check the ground by the battery...perhaps its bad too.
#34
Eh, boy. Fix the engine ground before you go any further. I have read that if bad, the DME can fry. Sparks are pretty bad. There is another ground ~20mm away from that one, dress it too while you're at it.
To be clear, no tachometer response at all when cranking? I thought it was supposed to bounce.
#35
#37
CLEAN THE GROUNDS. Then re-attach. This was no suggested so that we can all PM each other and laugh about getting you to do unnecessary work. It was suggested because it's a contributing factor to this issue. Especially now that it's been arcing, and has undoubtedly built up carbon deposits on the grounding surfaces.
#38
No, you need to pay attention to what people are telling you if you want to continue to get advice.
#39
no,the intake manifold is on,and im not taking off again..it was only sparking when it was loose,its pretty clean and should not need a cleaning..its easy to tell someone what to do behind a computer,why dont u get ur *** here and help me,cuz i worked my *** off on this car..im so sick of this..
2.) People are trying to help you. But I really don't thing anyone is going to just bail you out of your mess.
If you're that frustrated, just walk away form the car for a while. Or sell it.
My head assplode.
#40
im trying man im trying,i cant walk away i need a car...i thought about selling it,but how stupid would it be to sell a car with a good motor and rest, just no spark on plugs,and i came this far,like you guys said..dose not make much sense,and i have been dealing with motors fo a couple years i cant belive i cant figure this out,i usually figure everything out on my motorcycle in no time and fix it..i dont get the last comment,do you a S?
#42
i talked to a porsche machanic just now at a shop,he tolled me how to test the hall sender and ill test it,and looks like ill be getting a new one,since i cant have the wires like that anyway..
#43
Captain Obvious
Are all the grounds now clean/tight?
#44
#45
