Time for a zinc parts post - current collection
Laid everything out to see what was there Thought you guys might get a kick out of these pics. Everything is for sale by the way and I'll post prices at the bottom.
Exhaust manifold heat shield - $45
Cruise control motor - $45
Front sway bar drop links - $25
Front sway bar brackets(smaller) - $10
Coil strap - $5
Head rear water pipe - $15
Turbo water pump bracket - $65
Parking brake hardware - $15
Turbo y water line - $45
Engine bay harness brackets - $15
Hood upper and lower latches - $45
Turbo oil feed line - $85
Turbo short water line - $35
Turbo mount AOS line - $45
Turbo oil return line - $85
Hatch latch brackets - $5
Reference sensor bracket - $10
Front engine water pipe - $45
Idle control valve bracket - $45
Spare tire hold down bolt - $15
Engine heat shield bracket - $15
AC tensioner bar - $35
PS tensioner bar - $35
Emissions/test plug bracket - $15
Turbo dipstick tube - $45
NA dipstick tube - $25
Front turbo exhaust hanger - $15
AOS heat shield - $35
Master brake cylinder heat shield - $55 (Has two small holes in it)
Starter heat shield A - $35
Starter heat shield B - $35
Rear turbo exhaust hanger - $15
Fuel rail and jump line - $145
Engine oil pan seal heat shield - $20
Turbo steering linkage heat shield - $10 (Has small crack in it - works fine)
Rear drop links and camber bolts - $65
Headlight bar and hardware - $35
Turbo vacuum manifold - $25
Hood light socket - $10
Front shock upper mounts - $85
Wastegate mounts - $25
Door regulators - $10
Front brake lines - $45 pair
Rear brake line - $10(for one side as that is all I have)
Rear cam tower engine hoist bracket - $10
Cruise control assembly - $65
Front caster blocks - $25 each
Coil strap - $5
oh and the engine hooks both the front and the back haha and the hood latches.
and do you have hardware for the oil cooler(the engine mounted one) and the hardwear for the water pump, bolts for the cam cover and the head bolts?
and the pipes in this picture
