LOOKING FOR WHITE GAUGE FACE REPLACEMENTS
6th Gear
ANYONE KNOW WHO SELLS WHITE GAUGE FACE REPLACEMENTS FOR A 1987 944T? ALSO IS IT TRUE THAT IF I DISASSEMBLE THE SPEEDO IT WILL HAVE TO BE RECALIBRATED? HOW EASY DO THE NEEDLES COME APART? I HAVE THE ASSEMBLY ON THE BENCH. I WANT TO CLEAN ALL THE CONTACTS AND CHANGE THE BULBS. I REALLY LIKE THE LOOK OF THE WHITE GAUGES.
Andre
I did this a couple of years ago and am happy with the results. The e'bay set included a "needle" remover that will pull off the needles just fine if you don't get ham fist-ed. The gauge panel removal went well,installation was easy. The only problem I had was putting the tach needle on. I ham fist ed it and bent the needle shaft. In the end ,I sent it out for repair and calibration. Yes it was about $200. If your careful and follow instructions you should be fine.
Fred
Fred
No, not Mosquito!
say what you want..my white face gauges are great! I had mine done professionally by North Hollywood Speedometer...they were about the same price as Palo Alto Speedometer..but I liked NHS's people better.
It was on the expensive side, but here's what I did:
White faces
Blue LED lighting
New Dayglo orange needles all around
fix odo gear
calibrate all gauges
re-calibrate temp gauge to read in Farenheight rather than "HOT" and "COLD" or whatever it used to show.
Polish the clear cover so it looks new
Total was about $700 including shipping to/from them in Cali.
White faces
Blue LED lighting
fix odo gear
No, not Mosquito!
White faces
Blue LED lighting
fix odo gear
White faces
Blue LED lighting
fix odo gear
MMmmm.. Pics?
