View Poll Results: Are you still a timing belt virgin?
Yes, I only trust a professional to do timing belt work on my 944.
19
11.95%
No, I do all timing belt maintenance work on my 944
89
55.97%
Yes, but I hope to learn how with help from Rennlist.
51
32.08%
Voters: 159. You may not vote on this poll
Old 04-14-2009, 06:28 PM
  #61
black944 turbo
black944 turbo's Avatar
Hey guys just finished the belts for the first time, YEAH YEAH!!!!!
I have one question, is the balance shaft idler suposed to touch the belt on the top (meaning between the tensioner and upper balance shaft)?
Thanks, Richard
Old 04-14-2009, 06:30 PM
  #62
alxdgr8
alxdgr8's Avatar
I did a FOES 2days after purchasing my first Porsche (87 924S)
Old 04-14-2009, 07:42 PM
  #63
Mark-87-951
Mark-87-951's Avatar
I dealt with it when I pulled/replaced the head and will be dealing with it again now that I'm working on replacing the front crankshaft seal.
Old 04-14-2009, 07:59 PM
  #64
Fluidplay
Fluidplay's Avatar
Just did mine by feel after replacing some noisy lifters, but ultimately had a P-shop check it, just to make sure. As it turns out I had it a little tight. Next time it will be spot on.
Old 04-20-2009, 03:47 AM
  #65
Luis de Prat
Luis de Prat's Avatar
Thanks, Richard
Factory manual spec is 1mm separation between the belt and the idler you are referring to.
So, is everyone retensioning at around 1K miles?
Old 04-20-2009, 07:29 AM
  #66
Landseer
Landseer's Avatar
Yes, using twist method.
Old 04-20-2009, 08:26 AM
  #67
black944 turbo
Is it 1k miles or 2.5k miles to retension, I here all different stories about this?
Old 04-20-2009, 09:09 AM
  #68
CurtP
CurtP's Avatar
I've re-tensioned the belts twice in the last year that I've owned this car and this weekend was my first belt change. Not too complicated, but finding issues from the PO makes the job harder. Rollers and seals were original ('87 951), belts were in pretty good shape and the year cast into the water pump was '98. I had to remove the water pump because the PO had pinched a wire under it! I'm not absolutely sure, but I think it's the oil level sending unit wire - which is strange because there's no oil level sending unit in the oil pan (not even a place for it). When I pulled the water pump off, the end of the wire broke off. The only problem I've caused myself so far is I damaged the crankshaft main seal trying to get it installed - of course, it isn't available locally.
I'm probably going to get the wrath of RL, but I reused the water pump and I didn't use a gasket (Permatex Ultra Copper).
Old 04-20-2009, 04:01 PM
  #69
Yummybud924
Yummybud924's Avatar
good question. i'm not sure aswell. my gates instructiosn that came with the belt say to check it after 3200 -4000 kms.
what's strange is that they have different recommendations for different countries... like it is says check it at 3000 kms for the U.S but 3200-4000 for Canada.
Old 04-20-2009, 06:06 PM
  #70
lovemyp-car
lovemyp-car's Avatar
hehe...i'll never have to do one on my 944. i'll probably do one on the engine i pulled though, go through that engine really well and rebuild it to put it in the 924S
so, yes still a t belt virgin
Quick Reply: Are you still a timing belt virgin
