Cold Weather + Door Handle. EDIT: STUCK WINDOW
= Broken.
I went to open my door and with just a bit more pressure the trigger went all the way back without opening the door .My driver side door handle opened effortlessly before, which is weird as the passenger side has always been a bit stiff but that one didn't break (knock on wood)
It was the biggest PITA for me to change my moms door handles to 968 handles and I swore I would never do it again. I actually didn't even do the driver side yet as she doesn't drive the car because I just can't work in that area. My fingers are way too big and it just sucks. I'd rather doing my timing belt/waterpump then the door handles.
Anyone have any advice on replacing them? Getting the plastic clip on the arm on the door handle has been the biggest problem for me (along with adjusting it properly)
Also, on my moms car, one of the tabs on the door handle broke in the same situation. If that is the case with mine does anyone have a cheap porsche script handle?
I just went through this on my re-assembly. As far as I'm concerned, all of this fishing your way through the hole on the outside of the door and/or popping roll pins simply doesn't work. I know it does for some, and good for you.
I have an 85.5 with the original door on the passenger's side. I can get into that door and access what I need to if I put the plastic piece for the lock on the handle first and drop it through the hole. Just screw the door handle in, and then work from the inside with the inside door panel off and the window up. I use a small pair of vice grips to press the door actuator plastic piece on the ball, and the door lock plastic can be put on by pushing on it with a screwdriver.
The new door on my driver's side is an 86. I believe this is when they started putting crap in there to try to defeat slim jims. Or maybe it's just for power locks, which this door had and I removed. In any case, the factor service manual is dead on (surprise). Pull the window. Yeah...its a PITA, but its not that bad. Then you can unscrew the bottom door track with a bolt on the top and bottom. You don't even need to take the gasket/window guide out. Once that's sitting in the bottom of the door, out of your way, it's cake to do whatever you need to the door handle.
ugh.... my little brother tried opening the pass window today (frozen) and now the window is stuck 1/2 day
I am getting pretty pissed off....can't really blame this one on the car but common sense says WTF would you open a window when its 10* outside and its obviously frozen shut
can I raise the window manually and leave it up for the winter?
v2 have you found my sisters myspace etc yet ?
You likely have pulled it out of the track. Have you tried to just put it up? If so, what happens? If it doesn't work, you'll need to pull the inside door panel off and see what's up. It probably isn't that bad, and the problem will likely be obvious.
When I try and raise the window with the button, it doesn't move or make a noise. When I try pulling it up by hand it doesn't move, but if I pull harder it moves a little bit and then springs back. Best way to describe it is stuck.
It is f'ing cold, I need to motivate myself to get out there.
It's a crappy job where you're reaching into the door and working blind a lot of the time, so it would be difficult to even take pictures of it.
