944S cams installation
Old 12-12-2008 | 07:41 PM
  #31
jstand22's Avatar
jstand22
wait by belt do you mean cam chain?
So with both cams in you now want to verify that the block is at TDC, and the cams are at TDC. If you need to move the cams a little you can....there is a spot on the exhaust cam where a large open-end wrench will fit so you can turn it....You want those pointers to point up from the head, not up to the sky....so you want the short flat part to point directly up to the sky while the corner (pointy part) points out directly perpendicular from the head.
Make sure all the carrier bolts are torqued to 15 ft-lbs, no more.
Install the chain tensioner (i think those bolts are only torqued to 7 ft-lbs, be careful with them). Install the J-tube to the tensioner. (hollow bolts are also 7ft-lbs)
With this done you now need to tighten that big 10mm cheesehead bolt that bolts into the cam, holding the cam gear on. If you have the retaining bolts put them in so you don't loose cam timing. If you don't have the bolts, get an assistant to hold a large wrench on the spot on the exhaust cam, and hold it steady against the torque you apply to the main cheesehead bolt. This bolt is to be torqued to 48-52 ft-lbs.
Old 12-12-2008 | 07:54 PM
  #32
RED87944S's Avatar
RED87944S
no,i mean the timing belt i put that on also...The cams look just like in your picture,and the engine is at TDC..
Old 12-12-2008 | 08:27 PM
  #33
RED87944S's Avatar
RED87944S
tomorrow ill just torque them like you said...then all i have to do is the intake and injectors..and we will see if i blow her up...
Old 12-12-2008 | 08:41 PM
  #34
Clint's 944's Avatar
Clint's 944
Make sure you turn the motor over twice by hand to make sure the timing is right before you start it!
Old 12-12-2008 | 08:45 PM
  #35
jstand22's Avatar
jstand22
Wait so you already have the belt on? That means you already torqued the cam gear on with the big cheesehead right?
Old 12-12-2008 | 08:55 PM
  #36
RED87944S's Avatar
RED87944S
alright ill turn the engine few times..
Old 12-12-2008 | 08:59 PM
  #37
RED87944S's Avatar
RED87944S
yes i put the belt on.. no...its tight but its not torqued..the problem is i dont have a torque wrench now,i have to get it back tomorrow and torque them where they should be at..
Old 12-12-2008 | 09:18 PM
  #38
jstand22's Avatar
jstand22
gotcha
Yeah, be sure to roll the engine over twice to make sure it doesn't hang up.... then check the belt tensions after the first and second rolls. Good luck!
Old 12-13-2008 | 07:10 PM
  #39
Clint's 944
So....how did it go?
Old 12-13-2008 | 07:22 PM
  #40
RED87944S's Avatar
RED87944S
not done yet..i have the intake to put on and injectors and thats it..i turned the engine few times and everything seems normal..
i want to clean my injectors before i put them on..is there anyway of me cleaning them up maybe soaking them in gas? or just find some shop locally to clean them up?
ill let u guys know when i start it...i have to get it done tomorrow..
Old 12-14-2008 | 01:52 PM
  #41
jstand22's Avatar
jstand22
Maybe a local machine shop in your area has injector cleaning services? Make a few calls. I saw you said you have to get it done tomorrow, but if you have a few days send them to Witchhunter.
Now why did you have the cams out in the first place? Were you replacing a head gasket?
If yes: You should have put new oil and a filter in there by now, if you haven't, do it, you don't want your bearings sitting in a coolant/oil mixture. When you start it let it run up to operating temp, then change the oil and filter again...Yes 2 oil changes.
Good luck! I hope it works out for you.
Old 12-14-2008 | 02:26 PM
  #42
RED87944S's Avatar
RED87944S
i replaced the head gasket,intake gasket,and the lifters,my plan was to change the oil twice i got the oil yesterday for 2 changes and i guess ill get another filter because the filter i have on the car now is new..ill see if i can find some one local to clean them up other wise,i am just gona put them on and have them cleaned while on the car..BIG THANKS for the help!
Old 12-14-2008 | 07:58 PM
  #43
RED87944S's Avatar
RED87944S
ok got done...i am cranking it and it kinda cranks slow,and its not starting,maybe i have the cams a bit to tight? or i need to keep cranking it untill the gas goes thru the lines? i knew i was going to have a problem starting i expected it..i am also charging the battery
Old 12-14-2008 | 08:08 PM
  #44
RED87944S's Avatar
RED87944S
i could have tighten the belt too much?!..i know theres that spring tensioner,all i did with it was get the two bolts loose then and let it adjust and i tightened it back up..
Old 12-14-2008 | 09:04 PM
  #45
Jay W's Avatar
Jay W
2 things I can think of. Did you get the cam caps (whatever they are called) put back in the correct locations? They have numbers on them so that would be easy to double check. Since they are line bored, an out of place one will make the cam bind up. And I seem to remember someone over tightening the cam caps and the engine was hard to turn over due to the binding it caused.
Quick Reply: 944S cams installation
