Rennline Safety Harness Mounts **Product Release** $36
Basic Sponsor
![](http://www.rennline.com/images/products-release-image.jpg)
These brackets have been specially designed to allow you to install both, factory seat belts and aftermarket harnesses at the same time. Intended for the use of quick disconnect lap belts on both sides of the seat. This is a perfect set up for your street/track car. All brackets are designed to attach to the factory seat belt mounting locations so no drilling is required.
To purchase this item please click here!
![](http://www.rennline.com/images/sa02.jpg )
![](http://www.rennline.com/images/SA01-2.jpg )
![](http://www.rennline.com/images/SA02-2.jpg )
![](http://www.rennline.com/images/SA03-1.jpg )
I dont think this is allowed by the PCA for DE is it? I have a set from Brey Krause on the inside of my sport seats but thought they changed the rules...
It looks like they have some attach to the body...would that be legal? Rennline, is that accurate that some of your mounts can be bolted to the body?
thanks
thanks
Can someone 'splain to me what this is for? I have to assume it's not for a 5 pt harness....if it's just for a quick release lap belt...why would I want that if I do DE?
Please tell me what I am missing!!
Joe
It's hard to tell from those photos, but it's for the inboard side of the seat when using a 5pt harness. (which is all that's showing). HOWEVER, most of the PCA clubs want you to have real race seats in conjunction with 5 pt harnesses, so it's not as useful as it probably once was. The most relevant photo is the one where it's mounted to the tunnel since that'd work with fix back seats.
I have all that quick release stuff on my car (except on the inboard side). I never take it out since the car is dedicated to the track and driving to tech inspection and picking up parts and such.
Basic Sponsor
You really need to check with your club to see what is legal. They are primarily designed for DE and autocross events. If you are doing any type of actual racing then you wouldn't have factory seat belts still in the car. With that said, the short unit is used alot as just a quick disconnect harness mount on both tunnel and sill side of the car. These are basically a universal type harness mount that can be used in several different applications.
for autocross you can probably run a harness bar and a four point setup. if you do that the rennline setup is awesome. unclip the two lap belts when not in use.
if you have an early car, the rennline part mounts to the transmission tunnel. if you have a late car mount it to the seat.
For DE, you are supposed to have a five or six point system. if using a six point system and have an early car the sub and the lap can probably (pretty sure one bolt for both pieces is legal) bolt to the rennline part, and the part is attached to the tunnel.
if you have a late car, and the rennline part is attached to the inboard part of the seat you will probably be OK. i wish this was around when i had my first 951 and the momo seats. it was a mother getting the bolt for the belts on the inboard side not to stick out with the seatbelt, lap belt and sub belt on one bolt. having the rennline part would have allowed me to bolt just the factory belt and rennline part to the seat (or tunnel if i drilled the hole), and the loop on the rennline part would probably have cleared the tunnel because of the bevel of the tunnel.
another great thing about this rennline part (from my observations that is), is that you can use a six point system instead of a five point. if using a five point you have to cut a hole in the seat, and there are rules as to where the sub is mounted and how the sub belt is mounted.
I wouldn't say suppose to have for a DE. You should only use 5 or 6 points harnesses with a racing seat, and a lot of people that DE are using stock seats, which should only be used with DOT belts. The backs of stock seats are not designed to be used with shoulder harnesses, nor is there a place to run a sub belt properly. And vise versa, racing seats should not be used with DOT belts.
With what Tom mentioned about the Momo seats in his old 951 (now my 951), it would indeed make life alot easier. As of right now there are eye-bolts for the inner lap belt attached to the Wedge Engineering seat bracket, the eye bolt is basically pressed right up against the transmission tunnel. To get the lap belt for the 6-pt over so i can use it,i have to really muscle the stock female end of the belt over and slip the harness end over (its far to tight a fit to disconnect it. The outter side is not really a problem as there is plenty of space. Its hard to explain, but trust me when i say its a pain in the neck. Yea, i only need to do it when at an auto-x or a DE..but its a pain in the *** to do.
i bet one set would work great for both seats, and you can leave the eye bolts on the outside. glad i can spend your $$ for you. i know i will be on rennline's site come spring when i put the momo's into the new 951.
