Respray price
Old 12-07-2008, 12:14 PM
  #46
V2Rocket
Rainman
V2Rocket's Avatar
Originally Posted by porshhhh951
He did 5 coats of base and 3 coats of clear. Cut down after every spray and it was also wet sanded.
i bet that looks FANTASTIC
Old 12-07-2008, 12:26 PM
  #47
porshhhh951
Monkeys Removed by Request
porshhhh951's Avatar
lol it did. That was 5 years ago. Lots of hard driving since then
Old 12-07-2008, 12:58 PM
  #48
rluciano
rluciano's Avatar
Originally Posted by roman944
yup and I know a couple of places, kind of like mom-and-pop stores, they have been buying salvages bringing them back to life, and fixing colision cars, forever
also, whenever you do this, do NOT rush the painter, so assume downtime of atleast 1 week before you get the car back, if you want it done right
and don't annoy them with "dude where's my car?" stuff
One week?!? How about 3 months. That's what my car took, although at almost 2 months, the body shop had a fire and all of the parts that were off the car at that point were melted, toasted history. That meant new sunroof, new batwing, rear hatch and rear quarter windows, new door quarter window, sunroof and hatch seals.
Old 12-07-2008, 02:02 PM
  #49
porshhhh951
mine was 4 months.
If you want a better than factory job then don't expect a quick turn around.
Old 12-07-2008, 03:02 PM
  #50
Pcar944
Pcar944's Avatar
One of the advantages of having two.
Old 12-07-2008, 03:20 PM
  #51
Keithr726
Keithr726's Avatar
I decided to save money by disassembling and reassembling the car myself. Project took about four months and I just got it back from the shop painted and ready for assembly the other day. Unfortunately I've run out of time for the next week or so. All in all the project cost $ 9,500 with about $4,000 into frame and quarter panel repair. That means prep (the shop will find dents you never found) and paint came to $5,500. You can follow the project at the link below...
https://rennlist.com/forums/944-turbo-and-turbo-s-forum/445249-the-keithr726-body-project-thread.html
Originally Posted by Van
I'm in the process of getting mine ready for a partial paint... It's a lot of hours to take everything apart and clean off all of that adhesive...
(Anyone have good adhesive removing ideas? Specifically for the double sided tape under the "turbo" badge and the "porsche" sticker above the bumper?)
Try wrapping some thin wire around it and moving it around to remove the badge. As for the sticker heat will be your best friend.
Old 12-07-2008, 03:25 PM
  #52
roman944
roman944's Avatar
wow
it depends how busy your painter is; and your situation is such an extreme, that just sucks!
but if your painter says car will be done in a week, then figure 2 weeks and you should have it back
btw, I'm in process of locating another 944
Old 12-07-2008, 10:13 PM
  #53
Van
Van's Avatar
With heat, I was able to peel off both the badge and the sticker, but a gummy adhesive residue is left... I'd like to remove that so the body shop doesn't have to. I've tried bug and tar remover and goof off - but neither seems to work very well...
Old 12-07-2008, 11:27 PM
  #54
Lorax
The Impaler
Lorax's Avatar
Rubber eraser wheel
Old 12-08-2008, 12:15 AM
  #55
Keithr726
Keithr726's Avatar
at this point paint thinner and lacquer thinner can be considered "weak" and should work
Might not want the aircraft stripper just yet
Old 12-08-2008, 12:29 PM
  #56
harrisonrick
Captain Obvious
harrisonrick's Avatar
Sounds like a fair price. Enjoy, and document with lots of pics.
Old 12-08-2008, 02:31 PM
  #57
BMWM3PORSCHE944
BMWM3PORSCHE944's Avatar
In answer to someone's question, he is using the latest Dupont system.
Old 12-08-2008, 02:59 PM
  #58
951jamie
951jamie's Avatar
Sounds like a really good price!! What kind of paint and how many coats of clear?
Old 12-08-2008, 06:06 PM
  #59
DarylJ
DarylJ's Avatar
to make the car look GOOD you should pull off the mirrors, pull the rear windows, pull the hatch, pull the bumpers, pull the rubbers off the bumpers, remove all body seals, remove the sunroof, remove the lights and markers, etc etc etc paint the body parts all and then replace everything.
I don't even want to talk about how long this takes to do. I don't even want to start adding it up in my head yet.
Quick Reply: Respray price
