car died on me while driving
Unbannable
Gah! I wish I saw this earlier when I might have been able to do something. ![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
I have a spare DME relay for my '87 which, if it'll work, I"d be willing to let you use for trouble shooting. Unfortunately, I'm about to head out of town for the weekend and won't be able to do anything for a little while.
Where in Fairfax are you? Also, who did you tow the car to?
BB.
BB.
Got Nothin'
Primary suspect for no fuel. It's gets more complicated with no spark.
30 bucks for a new relay, swap it in, the car will start.
new update.....
installed the new DME the car is running but i need a new mass air flow reader or a new idle control valve i told him i will get the mass air flow first.. If i understood him correctly. I will keep you guys updated as much as I can. THANK YOU SO MUCH FOR ALL YOUR HELP.
ok new update! I know you are all excited. The tech has tested the fuel injectors and they are all fine. Here is what happening. One of my fuel injectors is cutting on and off. The idle was very low "a couple hundred" when he got it up and running. He had to adjust it a lot to get it to not stall. He thinks it might be the AFM. If anyone has one for sale please let me know i drive an 87 944 na
Oh yeah the hose connecting the AFM to the throttle plate is cracked this is most likely causing the bad idle any help, advice, or willing to sell parts let me know. thank you in advance
