car died on me while driving
I was on my way to class this morning. The car started up fine but I didn't even make it a mile with out it dieing. I waited a little and tried to start it again and it did but then died before I could even put my foot on the gas. I live in fairfax, va if anyone is willing to help me PM me and I will give you my phone number. I am not going anywhere so I will be online for a while.
DME relay, Speed or Ref sensor.
Just went through this nightmare.
Clarks-garage.com can be your friend on this one.
It is not enough to swap parts, although the relay is a very good place to start, after that, need to isolate whether you have fuel and/or spark.
The tech has said that their is spark no fuel. I am really hoping it is just a stupid relay
As I said before you better beat the tech to it if it's he doesn't regularly work on 944s. If he hasn't worked on that many 944s he will diagnose "no fuel" as a bad fuel pump...the symptoms are pretty much the same between that and a DME relay. A DME relay costs about $25 and a fuel pump is $200 if you're lucky. Replace the relay just to see, it is worth it.
