944 bellhousing cut away?!
Ok so I'm not sure if it's called a bellhousing or not, but I was removing the engine from a spare 87 944na and while unbolting the starter I noticed there was a man made chunk taken out of the flywheel assembly housing... bellhouse? (Whatever) It was almost directly before the starter on the bottom. I would guess it was cut out with a small circular saw, there are still marks where it cut but didn't cut through the metal - rather sloppy.
Is there any reason this would be there or that someone would intentionally cut a hole in at area?
Thanks! It's raining now so when it stops and I go back out to work on it I'll take a picture an show you so you can all scratch your heads with me and say WTF!
probably looks something like this?:
![](http://img.photobucket.com/albums/v296/Janove/Porsche%20951/DSC00111.jpg)
I'm looking to get this done within a few weeks too, on this pic a member of Porsche Club Norway did this for the same reason I'm going to, to access the "referance-screw" on the flywheel, wich in my case is missing, without having to lift the engine out..
