NEW PRODUCT: Clear Side Marker Assemblies
Cottage Industry Sponsor
In the past, I could only offer side marker lenses and housings separately. They continue to be available as such, and are ideal for custom applications (e.g. to make a smoked version with black housings, for a black car).
However, many have asked for a "plug and play" solution. This is now available. They come with silver painted reflector area, ready to be installed. The lenses are the same high quality and clarity I have always provided. Made from the highest grade materials available, they are very glossy, and won't fade or turn yellow over time.
As an option, you can get LED kits that look clear when the lights are off. This saves you from tinting the standard bulbs with translucent paint from the hobby store.
Here is the list of clear lenses and options currently available for 944 and 951 models:
http://marketplaceadvisor.channeladv...78036&c=794996
(or www.hookedoncars.com - Porsche - 924/944/951/968 - Lights and Lenses)
bobinnova (09-23-2022)
I just realized the image for the front ones doesn't work. I'll have to fix that tonight when I get home.
Here are the direct links:
Front:
http://marketplaceadvisor.channeladv...96&i=243681275
Rear:
http://marketplaceadvisor.channeladv...96&i=243681276
Front and Rear Set:
http://marketplaceadvisor.channeladv...96&i=243681277
Front:
Rear:
Front and Rear Set:
Here is a picture of an installed set, courtesy of one of my customers. I believe those were done with the black housings.
I don't have any pictures of the assembled units installed, since it's a new product. Hopefully someone will take and send me a picture soon!
Looks good, thanks Nicole!
Next, can you make replacement lenses for 944 NA fog lights? I know, the fog light lenses are glass and are non-replaceable. But they break (shatter)! So the people that would want them would have no problem breaking away the already-broken glass off of the housing to install a nice hooked-on-cars lens.
I believe the 928 OB also uses the same fog light.
Here are some pictures showing the clarity of my lenses versus others made with cheap materials Mine stay clear and glossy, and won't turn yellow over time.
Any of these still floating around for a 90 S2? Need pairs of front and rear side markers...already have the front turn signals.
Thanks.
Thanks.
