87 944S defroster and A/C activation blows fuse
Old 07-18-2008, 12:39 PM
martin944
martin944's Avatar
Default 87 944S defroster and A/C activation blows fuse
Hey guys, on my 87 44S, everytime I hit the defrost and A/C buttons on the module my A/C fuse blows. Anyone have this happen to them, any info appreciated. BTW, I tried replacing the control module that didn't fix it.
thanks!
-martin
Old 07-18-2008, 12:41 PM
KuHL 951
Hey Man
KuHL 951's Avatar
I can't vouch for the defrost button but a bad AC relay diode will blow the AC fuse everytime.
Old 07-18-2008, 01:33 PM
Spidey944
Spidey944's Avatar
As will the clutch on the compressor if it's bad. Too much current draw will blow the fuse.
Old 07-18-2008, 01:39 PM
Scootin159
Scootin159's Avatar
...or a wiring short.
FWIW, the link will be the A/C, as the defroster runs the A/C.
Old 07-18-2008, 05:49 PM
m73m95
m73m95's Avatar
Mine does the same thing.
I haven't really dug into it yet, but I'm thinking its the AC relay.
I'm going to try to get to it this weekend. I'll check in, and post what I find. (Might be a completely different problem on your car though...but anything helps.)
Old 07-18-2008, 09:36 PM
martin944
martin944's Avatar
Thanks guys, I tried replacing the relay, that didn't work for me.
Old 07-18-2008, 09:49 PM
m73m95
m73m95's Avatar
Ok, this was my #2 thing to check out.
These are from the "electrical clicking sound from glove box" post a few days ago, in this "944" section.
http://forums.rennlist.com/rennforum...99&postcount=2
http://forums.rennlist.com/rennforum...02&postcount=7
look for the post, and check out the links.
Old 07-18-2008, 10:59 PM
KuHL 951
Hey Man
KuHL 951's Avatar
el linko es stinko..no worko?
Old 07-19-2008, 12:04 AM
m73m95
m73m95's Avatar
Very strange. They work in the origional post.
I don't know how to find the address for the thread....I'll bump it so it'll be on the 1st page again.
Old 07-20-2008, 01:59 AM
testarossa_td
testarossa_td's Avatar
I say bad clutch. could be seized compressor...just know that it can go from bad to worse. The fuse does not always protect you. Next stop climate control unit meltdown...Just advance search using my name and compressor. Plenty of info, not just my two cents.
Old 07-24-2008, 09:38 PM
944buck
2nd Gear
944buck's Avatar
I had this problem and was able to fix it! It took a while to figure out though. I was able to use the system with the diode remove (it is behind the computer in the passager foot well spliced into a wire). But the true solution was on the Power Stearing Pump! There is a switch with two wires on the power stearing pump that has failed and shorted out. It is part of a circuit that tells the computer it adjust the idle if the a/c is running and the power stearing pump is under load. Use a multi meter to check the resistance between the terminals of the switch and body of the pump. If the resistance is zero, you have a short and the switch needs to be replaced! Who knew.
Old 07-24-2008, 09:46 PM
944buck
2nd Gear
944buck's Avatar
It's item 12 at this site
http://www.944online.com/cgi-bin/ASI...esteering-944s
Old 07-24-2008, 11:35 PM
m73m95
m73m95's Avatar
does a regular 944 have this switch? or only the S (or others)
Quick Reply: 87 944S defroster and A/C activation blows fuse
