PORSCHE embossed door panels!
No, not Mosquito!
No affiliation of course, but I thought these were cool. Seem to be rare, no?
http://cgi.ebay.co.uk/New-Cond-Inter...QQcmdZViewItem
Hey Man
If you saw them on an 83 they probably came from a 924. Maybe some of the very early Euro 944's had them but they were not standard in the US. My 83 was #610 and it had the plain ones. The lack of speaker holes is a dead giveaway they are from a 924. I was always looking for a set but they were next to impossible to find in brown. I saw a set at Pick N' Pull in black about 4 years ago on an early 924. I always liked them and have seen several sets go for well over $100 on eBay. Those ones above are for a RHD car also.
I have a set of brown w/speaker holes but not factory holes. Round instead.
They're for sale. PM if interested.
I always wondered if I were to buy panels like this, and recover them in leather, would the PORSCHE still be there? My question is then I guess, is the PORSCHE pushed into the wooden panel? Or when I took off the vinyl, would it be a flat surface on the panel? By the pictures I see, the back of the panel is flat, and dosn't show any indecation of the PORSCHE.
Given that there is no padding up top, if you used some good glue and really worked the area, you could cover the panels in leather and still have the PORSCHE show up. It's just like the indentions around the window switches, notice how you don't see those on the backside either.
The only real problem is the panel shape itself. It'll be tough to recover the whole door panel, due to the angles at top. Unless you were to do it in 2 pieces, and use some beading to mimic the factory appearance.
The pressed panel is pretty thick, so the Porsche indention can still be in the panel, and not show up on the back.
Hey Man
The key to get the new leather to stick and follow every curve is to use the right adhesive and a vacuum bag to suck the material down and hold it. My FIL did this for countless street rod interiors. He made his own bags from 20 mil clear poly and used a vac pump and shop vac fittings.
The key to get the new leather or stick and follow every curve is to use the right adhesive and a vacuum bag to suck the material down and hold it. My FIL did this for countless street rod interiors. He made his own bags from 20 mil clear poly and used a vac pump and shop vac fittings.
Pulling laminate or veneer off of a part that was never vacuum bagged isn't too tough with some thinner and a little heat, it'll come right off. But a part that was bagged is a serious task.
Most contact glues can take up to 6 hours to really set. So we'll bag parts for about 8-10 hours just to be safe. We also aim for a minimum of 20in. of vacuum.
I've been wanting a vacuum pump myself, but for a good used one you can spend up to $350. I've heard of using old refrigerator compressors, but I haven't explored that avenue yet.
