AC Compressor Clutch Bearing
1 Post
I should have posted this here first (it's also in the 944 Turbo specific forums)
Other post in 944T forum https://rennlist.com/forums/944-turbo-and-turbo-s-forum/434665-ac-compressor-clutch-bearing.html
I was looking for some help to find where to buy an ac compressor clutch bearing or the entire clutch assembly for my 86 turbo... original message follows
A-la scuba steve...
I found an old post which recommended Northside Refridgeration in Texas as a source for the Nippondenso 10p15 (standard late 944 ac compressor) clutch bearing. Unfortunately, they have gone out of business... So, I'm looking for another place to find it and my trusty paragon products only seems to carry the entire compressor.
The compressor is tested good and blows cold, the bearing is certainly on its way out. It makes the same grinding sound regardless of the clutch being engaged or not.
Anyone know another place to find this ac compressor clutch bearing? What about just buying a new clutch assembly?
I prefer to just replace the bearing, since I know the compressor and clutch haven't been used much (rarely actually gets hot here in Ct.!)
Also, I have a new receiver/dryer I don't need, let me know if you're interested.
Thanks,
Nick
A-la scuba steve...
Thanks,
Nick
1 Post
AR10, will do!
Just to check, has anyone done this before and happen to remember the part#? Would be great so I could have the part ready and throw it in.
Thanks,
Nick
Thanks,
Nick
Billowing in the Wind
Nick
It's been a almost two weeks. Did you get this done?
I just put in a remanufactured compressor and the clutch makes a horrible sound when the AC is off. Quiet when AC is on. I'm sure I could have gotten a replacement under warranty, but I bought the thing almost a year ago and just now got it installed. I'd like to know if you managed to replace the clutch and bearing and if you had to remove the compressor to do this. I'd prefer not having to do that.
1 Post
I did replace the bearing, however, the bearing that rockauto.com suggests for a 1986 944 Turbo is incorrect for the stock compressor. The part # should be 5001KFF not 5000KFF. The difference is that the incorrect bearing has an inner race that is the correct width, however the outer race is recessed which causes the clutch pulley to be too close to the compressor. So, with the help of a friend we fabricated a shim to make the bearing work.
In case you do decide to replace the bearing, make sure you've got something strong to push the old bearing out and put the new bearing in (like a shop press). The pulley removal tool is a must as well since I wasn't about to bang on anything to get the clutch loose. You may also find another post on rennlist that states you must be careful around the front carbon seal on the compressor. At least for me, I had no problems with this seal since it seems to be very recessed into the front compressor plate. I supposed a calculated jab with a screwdriver could do it or if you place the woodruff key in the wrong spot. Other than that, it's a pretty straightforward job (with the right bearing!)
After the new bearing, all is well and the AC works fine.
