Rear center jacking point?
UAE Rennlist Ambassador
I usually jack up the front of the car by placing the jack under the x-member. That way i can raise both front wheels at the same time, and place jack stands.
Is there such a place to use on the REAR end, to lift both rear wheels off at the same time?
Can the t-bar housing take it?
I have done it on the tranny. My perferred method is the side center jack points. I jack up my race car at least twice per weekend doing tire rotations and checks and do it this way all the time. I have used the tranny only if needing to do just the rear wheels and I don't have the same for the sides.
I normally raise the rear from one of the rear jack points and then place a axel stand under torque tube. It work good for me and with one stand I can keep the whole rear of the car lifted safely.
Official Rennlist
Borat Impersonator
Borat Impersonator
I would not jack using the trans or place jack stands under the torque tube.
U can use the torsion bar tube if you can reach the center of it.
just use the jacking points there are like 6 of them, so you have to jack twice to get the rear up. Better than changing your trans mount.
Herr Unmöglich
I use the cross member very frequently for the front end. Normally I would use the side jack points to deal with rear tires... but if I need both rears off, I have been known to jack from the bottom of the trans, and then place stands on the torsion bar housing.
Official Rennlist
Borat Impersonator
Borat Impersonator
I would not place the weight of the car or half the car on the torque tube. The torque tube attaches to the engine up front and the trans at the rear.
It is not bolted to the body, putting a jackstand on the the torque tube is like putting a jack under the trans or under the engine. not good.
just put the jackstand under the torsion bar tube in the middle.
