A wheel question
Hey Man
I asking this for a non RL friend. He has an 87 924S. He picked up some used wheels for it and has an issue with the front fitment. The fronts are 964 Cup2's in 16X6 and the rears are 968 Cup2's in 16x7. The wheel centers will not clear the front dust cap flange and the wheels can't be machined enough to clear. Has anyone ever tried brazing the straight sided inner part to the dome of the dust cap from inside and removing the outer flat part of the lip? The wheels will clear everything but it's that outer flange of the cap that interferes. He has to retain a cap for the early style speedo drive of the hollow spindle. He was hoping to drop the front an inch or so and having to use a spacer for hub clearance would be a problem. Is there any other method to provide that front cap clearance?
Hey Man
Thanks Dan. He was already running a 6mm spacer and still had at least 1/8" - 3/16" of contact with the dust cap flange and rear of wheel area. I wonder if the offset he has from the 964 Cup version is different or something? I haven't seen the set-up so I'm working with verbal info.
Let me see if I'm understanding you right... The wheels won't go on because the grease cap's outer lip is sticking out (radially) too far? Or is the cap sticking out (axially) too far?
Since I'm not sure I understand I can only offer generic advice: maybe slight shaving on the wheel, and slight shaving of the cap, and a thin spacer, might add up to enough clearance?
Hey Man
The problem is that the flap part and the dome is one piece folded over. If you cut that part off, the dome will separate. I left the cap off and used the wheel cap after I siliconed it shut. There is a way where you don't need the spacer and still have the wheel fit. I cut a bevel into the aluminum hub only a little bit leaving most of it intact so the wheel is still hub centric.
Hey Man
My solution to him was more elegant; just put his old PD's back on it and be happy!
Lego said right. Its not the diameter of the dust cap, but the inside of the wheel is tapered toward the outer center cap area. The inward taper of the wheel can be machined a little and it will fit. I have done this (sic) with a hole saw on a drill. It should only take a millimeter or so. Also, I was able to get more clearance by taping the dust caps outermost edge with a ballpeen hammer inward toward the rotor while slowly turning the entire hub. When it all fits together, the center cap will most likely not fit. I cut the plastic retaining tabs off the center caps. Then I drilled two small (1mm) holes through the outer edge of the center cap into the wheels inner lip/stop for the center cap. Then I simply screwed two very small chrome plated screws into the cap/wheel to hold the cap on. And the drivers side center cap - I simply drilled a 3mm hole in the center of the cap to make room for the speedo cable end protruding from the hub. At a glance it is completely unnoticable. My boxter 16"wheels had perfect offset for my 924s. If I remember it was like 53.8mm stock, 55mm boxster. With the added wheel diameter it works perfect. Mine rubbed on the rear fenders but I was able to roll the fenders only about 2mm and problem solved. If needed I will post some pics. Let me know.
