which is more reliable, 951 or 928?
#91
Rainman
i think the issue with the 928 transmission is the f-ing crossmember that goes underneath it.
its easier on the 944, its like 8 bolts and yank.
iirc the battery is next to the spare tire right?
#92
#93
Not sure I follow.
- door panels
I've had mine off a few times, what's the issue?
- fenders
Never had to do this, so I cannot comment.
- transmission
??? It's a piece of cake to remove.
- sunroof
Mine works, so again, neutral
- coolant tank
Took me about 30 minutes to swap (took extra time to collect coolant)
- intake
I'm demonstrated how I can remove my center plenum(16V) in under 10 minutes![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
To remove the rest is not difficult either.
- battery
??? Very easy to get at. The gromet on my 944 battery was bad. I found out when it leaked water / battery gunk into my cabin, ruined the floor mat.
- door panels
- fenders
- transmission
- sunroof
- coolant tank
- intake
- battery
And as you mentioned the heads are also harder to pull. And there's two of them
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
Item by item, it's not much worse than a 944, but collectively, it can really make you
But I suppose the real question is reliability (as per the topic of the thread). The only thing I mentioned that pertains to reliability is the intake. The less gaskets, seals, o-rings and boots, the better. Am I wrong?
#94
Ever take the gas tank out of a 944? That damn spare tire well is in the way, you have to take the transmission down in order to do it.
928, unscrew 4 bolts, 2 hoses, tank on the ground.
Transmission is not that big of a deal, 8 bolts, disconnect some cables and it lowers easy.
Door panel, if you are complaining about a door panel, quit doing mechanical work, it's not for you. On the 928 it's unclip one panel, take out 3 screws 4 bolts. Or was it 4 screws and 3 bolts? Takes 5 minutes.
Water leaks, all cars will have water leaks with age, simple fixes.
Fender? a few bolts on top, take out the side marker after you remove the whell well liners and 4 bolts to the bumper. Admittedly, the last bumper nut is a bitch, but a 1/4 drive with a 8mm and 12" extension makes quick work of it. Took the both front and rear bumpers off a GT last weekend, took 2 hours.
#95
![](http://www.vwvortex.com/vwbb/sly.gif)
I've never removed a 944 gas tank so I'll take your word on that one. Thanks for bringing that up, I didn't know.
#96
I got all of you outdone. I can take off a door panel in under 2 minutes, take off a fender with the removal of 8 bolts, and can do the tranny job by myself with my arms. Well, the fact that i have manly buff arms helps too because I drive a man's car with no sissy steering assistance ![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
In other words, arguing about who's car is easier to work on is pointless. Things are naturally 'easier' for some people than it is for others.
#97
Administrator - "Tyson"
Not, but in a thread that has been going on this long we get to argue about the little things now
#98
Rainman
i had to benchpress the end of the tranny while my dad hooked up the chassis mounts...and of course the bolts wouldnt line up...
X_X
now we need to change the topic of the discussion to...
"which is prettier, 951 or 928?"
X_X
