Clutch Fork Bearings
Forum Members,
I have a used clutch release fork that I plan to clean and install in my car. My question is how does one replace the bearings in the fork? Are the pressed in and out?
PorscheDoc, assume pressing them in/out with a similar sized socket and a hammer is not a wise idea. Am I correct this would be better accomplished at the local shop that can use a press?
Ideally they should be done with a press, but I can't say that I haven't done them in the past with a hammer and socket with no adverse effects.
ive done quite a few w/ a hammer and a socket just slightly smaller. Works great just make sure they are lined up square when you go to put them back in w/ a rubber mallet.
