Safe to assume this is the temp gauge sensor.
Temp gauge sensor?
I think I may have to redo the connection. Can it be soldered or crimped?
SoCal Driver comes from the grave to answer.
"If it was only the temp that was acting up I suggest checking the sender connection and the wire from it. It's on the block behind the DME temp sender. A bit under the intake runner for cylinder #1. The connector is special for the button head sender so don't cut it off and try another. I've had to solder a new section of wire in between the connector and the harness to get rid of the green wire disease."
So any solutions for fixing this connection?
