brand new 20 years old 944TS
#136
When you use PET from a Porsche Dealer it does make a distiction. When a car is a full Turbo-S, it shows as such. This car listed shows as a Turbo only. However it has under its options: M758 = Special Model 944 Turbo S '88. This is done at the factory however, and not a kit. Though, this is the first time I've seen it shown as such.
You can also tell via other Porsche resources, with the VIN. Everything about what the car has on it. Paint Codes, Interior Codes, etc.
Also, as I look closer at PET, it should indeed have a 180MPH speedo, S or Non-S reguardless.
That makes no sense. Turbo S cars are not a dealer-option kinda thing, there are extensive changes to the body that is done at the factory. It's not a kit that gets added on. You can't tell a Turbo S by the VIN either, the VIN shows no distinction between Turbo, Turbo S or Silver Rose.
If there was such a thing as a 'Turbo S package' it would not mean the car should have a 160mph speedo.
I had a twin to this car, a Stone Gray over black script 1988 Turbo S and it had a 180mph speedo, and an equalizer for the 10-speaker system. All Turbos, S or non-s, after early 1987 should have a 180mph speedo. All 10-speaker cars should have that EQ. If the car is a real time capsule car no one in their right mind would remove or change equipment like that.
A car like this, it's worth $15k based on the condition (or so I'd guess from the pics.) Any more they get for it is based on provenance. Any more they get based on false provenance is stolen money.
This car is a bit of a mutt I'm afraid.
-Joel.
-Joel.
#139
At some point it just beggars belief. A 10K mile time capsule car, that just happened to get an oddball speedo from the factory, and a delete of the EQ?
I suppose if it was lying around a dealership for years a few parts might wander off. Who knows?
Too bad there isn't more documentation.
#140
#142
In 1988 and 1989 Porsche was in Deep financial troubles, the 88 turbo s was meant to be 1000 units built, with about 700 earmarked for US sale, the first 300 sold so fast they quickly increased production plans to 1000. the original turbo s had no sunroof, headlight washers, a/c, power windows etc. US market came fully optioned, with sunroof, a.c, central locking etc. and all were meant to be silver rose. somtime in 88 Porsche opened up and allowed turbos to be ordered with the 758 package as an option (much like how you can order a new 911 with the x51 package) instead of 1 way or else deal. In hopes to bring unit sales up some more. So technically it is not a turbo s by model designation, it is a turbo with the s option package. My turbo s (silver rose) has the 490 without the in dash e.q. and its is the original radio, same factory antitheft code that is stored in porsche records. It also does not have any wiring for the eq. so it was not removed. Porsche wiring harness are built vin and option code specific any how.
Most of the non silver rose turbo s's were ordered in this fashion. because the us market was not hot on the interior combination, rainbow checkered plaid stripes on the seats and door panels. So actually there is only about 300 or so model designated turbo s's. And most were sold in europe. I will also check PET tommorrow about the 160 mph speedo deal and may be call a 944 guru in PCNA.
Semper Fi.
Semper Fi.
#143
Found it on www.autotrader.com. Asking price is $29k. http://www.autotrader.com/fyc/vdp.js...ce=&cardist=40
They're selling Jerry Seinfeld's 993 as well: http://www.autotrader.com/dealers/in...ASC&cardist=25
#144
#145
So i guess when you cant represent a car you want about 100k+ for provenance correctly...
#146
fyi, every 951 in 88, regardless wether it was turbo-s or not, came with the 180mph speedo. the 180mph speedo was not a turbo-s package, it was a 1988+ model year change.
#147
I maintain that the EQ is a part of the 10-speaker option and the EQ should be there. if it is not, that's an anomaly. There was no option code for a 10 speaker setup without the EQ/power booster, and with what I know about factory car audio I do not think they would spec a system like that without the additional amplification.
Yes, OK there might be a car or two that left the lot without the EQ (probably did not leave the factory that way.) I worked at a dealership when I was in HS and those guys would add and remove a few things if that's what it took to make a sale.
According to the Autotrader ad, the car has never been titled. If so I would wonder if the car got messed with a bit and a few parts borrowed off of it over time. Someone might have wanted to upgrade to a 180mph speedo, someone wanted an EQ. The car was just sitting there.
It must have worn dealer plates to get almost 10k miles without being titled. Can you put any number of miles on a car before titling it with the MSO?
Found this on ask.com
"demonstration vehicles for test drives and such that can be driven up to 10,000 miles and still be considered “new” because they were never registered to an individual, although sometimes those cars are available cheaper than if they were fresh off the assembly line."
If 10K is a magic number, the odd speedo starts to make some sense.
-Joel.
-Joel.
#149
If you look at any road and track or motortrend article on the 88 TS or 89 Turbo, under specifications it will list a 180 mph speedo. There is something fishy with this car. I sent an email to the ebay listing and never heard back.
