Balance system CAUSING vibration?
Rainman
A few days ago I went in to check the tension on my timing belt and while I was in there tweaked the balance belt a bit too. It looked like it had slackened a bit and so I got it back to a satisfactory amount of tension.
I know for a fact that the belt is lined up in regards to TDC/BDC on the pulleys, as I had to fix that some time ago when the vibration was pretty bad.
Is it possible that with my slight tightening I somehow threw off the balance system and caused more vibration?
Rainman
The teeth on the balance shaft pulleys and the crank pulley did not move at all, all that may have changed would have been the balance belt tensioner.
Maybe its my imagination? lol
Does the vibration occur at idle or at around 3k rpm? If at idle then it's most likely a bad motor mount (exhaust side usually fails first). If the vibration is at around 3k rpm then smooths out the balance shafts aren't aligned correctly.
My guess would be a small vacuum leak or something similar, causing a rough idle. I had a vacuum leak on my car last year, and it was more noticable when it was cold outside. Or it seemed so, anyway.
