Suspension Travel questions with Paragon coilovers and Rennbay geometry kit
My first post!!
Well I’ve been lurking on this board for quite some time and using all the info I could find to help me convert my 1987 N/A 944 to a street/de car. I’ve done pretty well so far and I am finishing up my front suspension with the following key components:
Racers edge camber plates
Paragon Koni coilover conversion kit 400# springs
Rennbay geometry correction kit
With the spring perch loose, I used a small jack to compress the suspension approximately where it would be with the car sitting on the ground (A-arms parallel to the ground).
Look at where the shock sits, you can see that my suspension travel is limited to about 1.5” before I start hitting the bumstops. This worries me a bit. I know people run their cars extremely low without problems but with the geometry correction kit my strut is effectively moved up 1-1.5” which seems to cut my suspension travel in half.
Is anyone else running a rennbay geometry correction kit and a paragon conversion kit together? Any advice is appreciated.
BTW I have to give huge props to Paragon and Rennbay for putting together great products.
Thanks,
D
Thanks,
D
I have nearly the exact same setup (same parts, but 350# springs), and have had no problems with suspension travel.... with regards to the struts. My biggest problem is I keep hitting my front sway bar brackets on the ground.
That said... I love the setup... I can easily keep pace with stock turbo's at DE's, and am at least 5 seconds quicker on a 60 second autocross course. 400# springs may be a bit harsh on the street (IMHO), but that's all personal preference.
Something is wrong with the picture
My first post!!
Thanks,
D
Thanks,
D
Can you post some more pictures...first picture.. from what I see you your setup is not right..
-BB
Keep in mind that not all the stuff is installed in those pictures - no brakes, no rollbar, and the spring perch is not set.
thanks for all the replies
D
My 944 spec car does not have much front travel either, but it does not appear to an issue.
The ball joints are not costing you and travel, but flat camber plates can take away 1 inch of travel.
The control arms are correct being flat. That is the neutral position that will give you the optimum camber curve during cornering. Like Joe said the camber plates could be causing some loss in travel but with your spring rate it should not be an issue.
BTW, the extended pins do not change strut height. They only change the level of the control arm in relation to the spindle. With standard pins your strut would still sit at the same position but the control arm would be angled up to meet it.
Thanks for the post and a great product. Everything went together easily and I couldn't be happier with results
I did not think about it this way - but you are 100% correct: the extended pins do not change strut height... I would have had to move everything up anyway to lower the car without the extended pins so disregard my comment in the previous post.
My goal is to set the arms up to be parallel to the ground as you suggested.
Thanks,
D
I guess I am not really concerned with the small suspension travel as far as driving on flat sufraces goes street or track. It's those potholes and offroad excursions on the track that worry me.
I'll try to post more pictures tonight to see if I can get anymore feedback
Thanks,
D
