will 275/35-15 tires fit all 4 corners?
Hoosier is now offering their A6 tire in 275/35-15 size. I'm thinking of getting these as they've got the smaller OD of the 225/45-15 tire I like for Auto-x (better gearing, lower c.g.), but in a 275 width. I'm sure they'll fit the rear, it's the front I'm nervous about. My hopes are that they'll be short enough an OD that the fenders won't come into play.
Has anybody tried anything like this? Any input?
Thank gosh, i was about to bust out the Red Foreman 'Dumbass' picture ive been saving...
Anyhow i think you will have issues with the front rubbing on the spring perch if you still have it. Thats just speculation though.
Rocket Scientist
Well obviously it's been proven here that 275s fit in the rear. With a small diameter of a 15" wheel, it should fit better then an 18". I have 265's up front with no issues on 18's (but I have 2.5ID springs). Danno fit 275 up front, had to grind off the small brake line tab on the strut (he also ran with 2.5 or 2.25 ID springs). You could make it work. Depending on offset of course. I would count on rolling the front fenders. Good luck!
