Pressurized gas tank!
Everytime I fill up my car or take the gas cap off the tank lets out a bunch of pressure, are 944 supposed to do this or do i have a plugged vent line or charcoal canister?
No help to offer, but my camry does this as well. Gets a lot worse/there is a LOT more fumes when the car/tank/weather is hot. So I'm interested in knowing if this is at true problem or normal behavior.
hmm no, it only has alot of pressure after you've driven for a bit. I was just worried it might dent the tank out or god forbid blow up lol with all the pressure in there.
The pointed metal valve is the shutoff valve. It connects to another valve that is a big plastic valve called the Control valve. The control valve is about a inch away from the shutoff valve. Make sure he vacuum lines are connected to both of them and here should be vacumm on both line with a warm running engine.
If you don't have vacuum on the Shutoff valve, check the Temperature valve that opens the Shutoff valve. It is connected to the back water port that bolts to the head. It has two vacuum lines on it, one goes to the throttle housing (always has vacuum) and the other goes over to the Shutoff valve. When the engine get above 130F, the temp valve opens and allows vacuum to got to the Shutoff valve. This opens the shutoff valve and pulls fumes through the Control valve that is connect to the Active Carbon tank. The active carbon tank connects to the gas tank.
