should I buy a 951 with a blown head gasket?
Old 07-25-2007, 05:20 PM
KuHL 951
Hey Man
KuHL 951's Avatar
Another thing to consider is how long it has been sitting broken. If coolant is pooled on the piston from a severe leak it can cause the rings to corrode and possibly seize to the piston and cylinder walls. The degree of deterioration is dependent upon how long it has been out of service. Hopefully the PO squirted oil into the cylinders before storing it and put the plugs back in.
Old 07-26-2007, 10:50 AM
cie_lab
Billowing in the Wind
cie_lab's Avatar
This may be a stupid question, but how do you know it's a blown head gasket?
I had a friend with a Honda convinced he had a blown head gasket but instead it was a leaky exhaust manifold.
Again, could be a stupid question, but I'd want to make sure that's what it was. If you find out it wasn't, be sure you don't tell the guy. Instead, make it sound like it's much worse. Yeah. Stick it to 'em!
(kidding)
Old 07-26-2007, 11:09 AM
harrisonrick
Captain Obvious
harrisonrick's Avatar
how cheap is cheap?
Old 07-26-2007, 11:12 AM
V2Rocket
Rainman
V2Rocket's Avatar
Originally Posted by MichelleJD
88K and the HG is blown?! That's a little scary. Sure it's not 188K?
Mine blew at confirmed 67,xxx
Old 07-26-2007, 12:13 PM
sharkwing1
sharkwing1's Avatar
like i said, I am just going by what the owner has told me over the phone. it sure would be nice if the head gasket wasnt blown! I think I could probably pick the car up for arround $2500. I figure it might be a gamble but I could easily recover the cost in parts right? When I owned my n/a a few years ago I rememver the turbos and their trannys were selling at a premium. thanks again
Old 07-26-2007, 12:42 PM
cie_lab
cie_lab's Avatar
Originally Posted by ausgeflippt951
If the car's in fantastic shape cosmetically and interior-wise, I'd offer $3k for it, under the pretense that you have absolutely no idea what all is wrong with it once you actually end up replacing the HG. Then, if the owner calls BS you can tell him that it's quite unusual for a car w/ 88k miles to have attained a blown HG, which typically means more bad things are to come.
So yeah, you I would actually offer him $2500 and probably go no higher than $3500, really.
+1 (esepically cosmetically)
Make sure you have planty of good tools and lots of room/time/patience
Old 07-26-2007, 02:04 PM
MyBlackCar
MyBlackCar's Avatar
Originally Posted by Wipeout
I just grabbed the price on the part that seemed right from Pelican in about a 5-second search. I bet it's generally cheaper/I got the wrong part.
Get the head gasket after removing the head and getting it back from the machine shop. You might end up needing a thicker gasket.
Old 07-27-2007, 03:22 PM
BKiller
BKiller's Avatar
A buddy of mine picked up a nice 86 951 with a blown head gasket. Got it for under 3K and it had 18" hollow spoke twist wheels and a Vitesse Stage 2 kit on it. Replaced the head gasket and a few coolant lines and the car has been perfect since...
Of course, it could of needed a whole new motor. You never know until you open it up.
Old 07-27-2007, 03:55 PM
sharkwing1
sharkwing1's Avatar
my only worry is it might need a whole new motor, which i cant afford to replace right now and I would hate to have it sit for even longer
Old 07-27-2007, 04:16 PM
cie_lab
cie_lab's Avatar
Have a mechanic check it out. Even if you pay $100 now to find out what's really wrong, it will be money well spent.
Old 07-27-2007, 04:36 PM
xsboost90
xsboost90's Avatar
if you buy it and dont have the $ to fix it- just let me know i'll give you what you have in it- then part it out for like 7k- or build it.
Old 07-27-2007, 04:47 PM
ausgeflippt951
ausgeflippt951's Avatar
Well said...ehem, take the hint, buddy. If it's in great condish other than the alleged blown HG, scoop it up for cheap.
Old 07-27-2007, 05:28 PM
ApexCars
ApexCars's Avatar
Originally Posted by sharkwing1
it only has 88k miles and its cheap.
Be warned. There is nothing more expensive than a cheap Porsche.
Old 07-27-2007, 06:02 PM
MM951
MM951's Avatar
buy it
thats how i got mine.. but i ended up having to replace the engine
Old 07-27-2007, 08:54 PM
aribop
aribop's Avatar
If you don't have the money to be ready to put an engine in it, you better pass on it.
Quick Reply: should I buy a 951 with a blown head gasket?
