Problem with exhaust bolts
I thought I'd take a few minutes to let the wound stop bleeding. In my clutch replacement journey I have the transaxle down. The tail pipe and muffler off. I'm having a bugger of a time with the exhaust pipe. This is the 2 flanges where the headers join the pipe. I sprayed the bolts but no movement. After awhile i decided to cut the nuts off. I can't for the life of me get the bolts to come out. Thats with a pointy air chisel too. What am I missing.
Thanks Dan. Thats encouraging. I thought maybe there was some hidden surprise hiding in there.
spray a ton of pb blaster and wait 2 mins. Worked pretty well for me, you might also need a u joint for some of the bolts. I punched myself twice in the mouth when I was trying to remove the bolts on the muffler to cat bolts =S ouch
Isn't that a bitch of a job and I have a lift even. My problem are bolts right up front. BTW the bleeding has almost stopped now.
try using a floor jack to help you break the bolts loose. Helps, oh and grease from the car helps stop the bleeding =) but is a pita to clean off the wound. Wear some gloves.
Thats good! Grease helps stop the bleeding. Haha. Actually I took to wearing nitrile gloves but they just keep my hands clean and do jack when knuckles strike sharp metal. I completely cut the nuts off the exhaust flange but the sucker is bonded. Tomorrow its the torch.
