Do i really need to put my belly pan back on??
Just asking because i took myne off for a timing belt job etc.. and now debating whether to spend the time to put it back on, it's in rough shape, there are big gapping corroded 3/4"ish sized holes where the 10mm bolts use to mount, and where the bolts thread into are broken and rusted bad.
Do i really need to put it back on??
Not Special
My car never had one...at least not since I got it. If you have a turbo, I've been told that it's needed for airflow, but I'm not sure about an NA.
Yea it's an 83' NA, The only issue i was concerned about was the mud/sand etc and cooling air, i guess just make sure the timing cover is sealed, I also only have a small belt going to my alternator off the crank (no A/c anymore, no power steering)
I was advised by the 944-Spec racers to put one on for better cooling. The factory designed the aero and cooling systems with it in place, so why mess with perfection
its the black plastic skid plate... I took mine off after a oil change pure lazyness... the engine does get A LOT dirtyer not though... kinda wish I put it back on... I was going to use plexi-glass and make a new one but I never got around to it...
yeah there are two covers down there... after the batwing, there's the one that is immediately aft that covers the radiator/belts under-area, and then there's a second cover, covering the oil pan, right?
If there is a cooling benefit from the cover, I should get one. Anyone got one?
From what I understand, the batwing is only/mostly for aerodynamics, while the main belly pan has a few purposes. One important purpose is to maintain the correct pressure behind the radiator, so air flows properly through it.
