951 -- How Much Boost is Too Much?
How much boost can a 951's engine handle? Just had a head gasket go and the P.O. of my car put an aftermarket chip in there, and was trying to evaluate that as a possible cause.
Going with the pack
is quite monotonous.
I ran 18psi on k26/6 for a long time.
If it was running lean that could be an issue - what chips/boost?
Was it pinging at all or were you having any other issues?
Not sure...it was overheating, so then I took it in to the shop, fan was broken and very little coolant, so fan was fixed and coolant restocked, and it continued to run through coolant, so I took it back and they found a bad head. I'm told there's no permanent damage, but i want to make sure it doesn't happen again. If it was the fan that broke and I let it get too hot, then that's one thing, but if a chip causing too much boost led to the overheating/loss of coolant and the resulting temperature fluctuations (not ameliorated by the fan switch breaking and causing more severe overheating), then I want to turn the boost down.
Going with the pack
Is there a boost controller in the car, or is it still using the stock cycling valve?
Do you know what brand of chips they are?
The only way to raise boost in a car with the cycling valve still in place is with a jetted banjo bolt - a restricter in the bolt that holds the line from the hard pipe to the cycling valve - it makes the cyclic valve see less air to make it hold slightly higher boost. But these still don't raise boost to dangerous levels when used with the right chip.
If your car does have a boost controller and you have no boost gauge other than stock, then you might have an issue...
Going with the pack
The KLR is one of the computer boxes - along with the DME.
It is possible that the additional boost could be a cause, but I believe it is unlikely.
If it were running too hot I would point my finger towards possible causes of overheating...
chip would most likely make it run rich. I would say if your fan was junk and it was getting hot, that would be the cause. Running too hot can warp the head slightly and blow the gasket out esp when coupled w/ boost pressure.
PHP Code:
I have the Weltmeister kit and just tested the boost pressure with a precision gauge. It would spike to 1.1 bar gauge pressure then come back down to 1 bar gauge pressure.
After you get the car running again maybe you should dyno it and have them trend boost pressure to see where you are.
Lou
Lou
Isn't Lart running water injection too though? That'll make a huge difference to the boost you can run.
Most people seem to go with 16-18 on aftermarket chips. I think only Danno (Guru chips) was the only one saying 18 and just about all the other ones suggest 16 unless you put race gas in. Of course you could spend a huge amount of time tuning it and run 26-30 like Special Tool does, but he's a bit different then most.
